Ask the Expert- Smart Licensing in Enterprise Switches and Routers
409
Enthusiast
Re: Static SIP Service
I am expecting one of the 20x dial peers to get matched as well.  So the incoming call should hit dial peer 100 first which connects the call to CUCM right?  But there should be a second leg using a 20x dial peer back to the sip carrier right?  I am not seeing that.  I attached the output show only the debug voip ccapi inout
Beginner
So you match the CUCM dial-peer because of the destination pattern. However, you should actually match the 200 dial-peer based on the "incoming uri via" which is preferenced over destination-pattern. Can you check (sh dial-peer voice summary) if the 200 really is up and running? When calling inbound your matching should be: Mobile --> Provider --> Dial-Peer 200 --> Dial-Peer 100 --> CUCM. For responses to Provider in this scenario the sip-profile inbound on dial-peer 200 should be applied.
Enthusiast
Good Call!  Being that DP 200 is configured as below, I makes sense why it would not be up.  I need to configure either an answer-address, incoming called number or destination pattern to the DP to go to an up status.  Being that DP 200 is used to accept the call from the Provider as you stated, I should add the incoming called-number to capture everything.  Correct?
dial-peer voice 200 voip
description Incoming dial-peer
voice-class sip profiles 201
voice-class sip profiles 200 inbound
Beginner
Yep- incoming called-number should do the trick and bring the dp up!
Enthusiast
Ok, Using DP 200 now and not ringing my phone but instead getting the SIP/2.0 404 Not Found error in the log.   I am fairly sure the CSS on the SIP trunk has access to the extension I am translating the DID to in CUCM.  Still showing the 10.1.6.x IP addresses in the TO: and FROM: fields.
Beginner
Could you share debug ccsip messages and debug voip ccapi inout please?
Enthusiast
see attached.  thanks.
Beginner
The 404 is generated by CUBE not by CUCM. You can give this a try to fix it:
voice class dpg 100
dial-peer 100
destination dpg 100
I think the SIP Profile works, as we can see in the TRYING message from CUBE, that From and To include the 209. IP address.
Enthusiast
I believe your right about SIP profiles working.  I made the change but am now getting 408 Request Timeout.  Attached is new debug output.  It looks like when using DP 100 to send the call out is causing the hang up.  this is how DP100 is current configured.  I have it bound to gig 1/0/1 which is the WAN interface.
dial-peer voice 100 voip
preference 4
session protocol sipv2
session target sip-server
incoming called-number 8T
voice-class codec 1
voice-class sip profiles 1 inbound
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
dtmf-relay rtp-nte sip-notify
fax-relay ecm disable
fax rate 14400
no vad
Beginner
Could you please share the current running-config with me?
I thought that DP 100 is pointing to CUCM.
Can you please change the dial-peer in the voice class dpg?
voice class dpg 100
no dial-peer 100
dial-peer <Enter-CUCM-DP>
Enthusiast
Sorry about that.. I was making a few changes last week with DP 100.  I set it back to where it was originally.  Attached is current running config.  The call should be using DP 100 to send the call out to the carrier correct?
Enthusiast
Update.  I am able to make outbound calls the new SIP Trunk.  It is using DP 200.   Inbound call to test number rings my phone but when I pick up there is no connection and my cell still shows calling.
combing thru the debugs I found that the SIP/2.0 Trying and Ringing are now showing the right IP address (209.x.x.x) but it is now the received portion which show the 10.1.x.x ip address which is the carriers internal IP's.
Is this still an issue on my end with the DP's or should I look to the carrier?
Sent:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 209.142.200.14:5060;branch=z9hG4bKdmrim7309otm0lighlo0.1
From: "" <sip:6162831487@209.142.200.14:5060>;tag=5679373
To: <sip:6162775094@209.142.200.14:5060>;tag=283044B8-1A57
Date: Tue, 12 Feb 2019 18:24:15 GMT
Call-ID: 1548058228-15951135@SFLDMIUP-C3SIPGW
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
P-Asserted-Identity: "" <sip:7771350@192.77.235.171>
Contact: <sip:6162775094@192.77.235.171:5060>
Server: Cisco-SIPGateway/IOS-16.6.4
Session-ID: 0000353e00105000a00080ce623bf878;remote=713a4e8f5fbc5c12a670ee27070804c2
Content-Length: 0
234795: Feb 12 2019 18:24:16.420 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:6162775094@192.77.235.171:5060 SIP/2.0
To: <sip:6162775094@10.1.6.47:5060>
CSeq: 1 INVITE
Max-Forwards: 69
Contact: <sip:6162831487@209.142.200.14:5060;transport=udp>
Supported: 100rel
Expires: 330
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, PRACK, REFER, SUBSCRIBE, NOTIFY, UPDATE, REGISTER
Accept: application/sdp
Content-Type: application/sdp
Content-Length: 259
v=0
o=- 272265216 1549995856 IN IP4 209.142.200.14
Highlighted
Beginner
Is the provider's IP always the .14 or can it vary?
You could give this a go...:
-> profile 200 should copy the IP from the provider into a variable and you can use it to modify
-> profile 201 sets the .14 as a fixed IP
... maybe I'm missing something but I guess it' worth a try.
voice class sip-profiles 201
 rule 10 request ANY sip-header To modify "sip:(.*)@.*>" "sip:\1@209.142.200.14:5060>"
 rule 11 request ANY sip-header From modify "sip:(.*)@.*>" "sip:\1@209.142.200.14:5060>"
 rule 20 response ANY sip-header To modify "sip:(.*)@.*>" "sip:\1@209.142.200.14:5060>"
 rule 21 response ANY sip-header From modify "sip:(.*)@.*>" "sip:\1@209.142.200.14:5060>"
voice class sip-copylist 200
 sip-header from
 sip-header to
voice class sip-profiles 200
 rule 10 request INVITE peer-header sip To copy "sip:.*@(.*)>" u01
 rule 11 request INVITE peer-header sip From copy "sip:.*@(.*)>" u02
 rule 20 response ANY sip-header To modify "sip:(.*)@.*>" "sip:\1@\u01>"
 rule 21 response ANY sip-header From modify "sip:(.*)@.*>" "sip:\1@\u02>"
dial-peer voice 201 voip
 description Outgoing 11 digit dial-peer
dial-peer voice 202 voip
 description Outgoing 911 dial-peer
https://kxiwq67737.i.lithium.com/t5/image/serverpage/image-id/38463i4AA8AAFF2D82B116/image-size/large?v=1.0&px=999
