Step to activate locate in a CUCM 8.6(2)
dchavarria
Please I need your help, I have a CUCM 8.6(2) and need to change de language in the phones to spanish, which is the procedure to change it in this version of CUCM ???
Thanks you.
David Chavarria
Jaime Valencia
You just need to install the locale and then it will be an option under the device config for you to choose
java
if this helps, please rate
Install it on all servers starting with the Pub and don't forget to reboot every server.
Chris
