07-30-2015 12:59 PM - edited 03-17-2019 03:49 AM
Hi All,
I would like to know how can I stop receiving Voice mail into my outlook from my phone extension in CUCM ? I just want Voice Mail into my Phone.
Thanks Guys
Solved! Go to Solution.
07-30-2015 01:12 PM
If using Single Inbox you would go to Unified Messaging/Unified Messaging Account Status and delete or disable there.
If not then you would edit the Message Actions under the user to not forward to Email.
07-30-2015 01:12 PM
07-30-2015 02:09 PM
Just adding to KKoeper's point:
There are two ways, you can get voicemail as an email into your inbox.
1. There is an SMTP Forward, i.e. the voicemail is literally forwarded as an attachment to your inbox and both copies are two instances of the same voicemail
2. There is a Unified Messaging where Unity Connection synchs voicemails with the Exchange Server and both servers keep track of the copies and if one instance is deleted or read, then the second instance is also deleted / marked as read.
Either case, I think you can simply add the voicemail sender email address into the Junk Folder and next time onwards Outlook should automatically do it, worst case scenario you can create an Outlook Rule.
07-30-2015 02:16 PM
Thanks Guys,
is good to know the options,
