Beginner
Strange error on SIP to SIP CUBE
           Hi, I have  a strange error on C2921 router configured as SIP to SIP CUBE, SRST, ConfBridge and transcoder. On console there is constantly showing this message:
SIP: Trying to parse unsupported attribute at media level
So I started with debug sip errors, events, info, and then have some detailed debugs...but when I enable debug sip calls...router gets unavailable and calls are not working so I have to recycle power to bring it up again.
Here are debug logs that I captured before router became unresponsive:
003143: Oct 2 14:21:22.900 UTC: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length:
Could not get Content-length
003144: Oct 2 14:21:22.900 UTC: //-1/FC1474A69B4A/SIP/Error/sipSPICheckRequestExt:
Failed checking for SIP Header: Max-Forwards
003145: Oct 2 14:21:22.900 UTC: //185404173/0B0D0B0D0B0D/SIP/Error/sipSPICheckRequestExt:
CheckRequest fail on method 101 error code: 483 and status: 483
003146: Oct 2 14:21:22.900 UTC: //185404173/0B0D0B0D0B0D/SIP/Error/act_idle_new_message:
Failed check request
003147: Oct 2 14:21:52.900 UTC: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length:
003148: Oct 2 14:21:52.900 UTC: //-1/0DF620979B4B/SIP/Error/sipSPICheckRequestExt:
003149: Oct 2 14:21:52.904 UTC: //185404173/0B0D0B0D0B0D/SIP/Error/sipSPICheckRequestExt:
003150: Oct 2 14:21:52.904 UTC: //185404173/0B0D0B0D0B0D/SIP/Error/act_idle_new_message:
003151: Oct 2 14:22:00.264 UTC: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
003152: Oct 2 14:22:00.264 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003153: Oct 2 14:22:00.264 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:2334C208
003154: Oct 2 14:22:00.264 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: -9567 Attribute mid, level 1 instance 1 not found.
SIP: -9567 setup attribute, level 1 instance 1 not found.
SIP: -9567 connection attribute, level 1 instance 1 not found.
SIP: -9567 Attribute label, level 1 instance 1 not found.
SIP: -9567 a=framerate attribute, level 1 instance 1 not found.
003155: Oct 2 14:22:00.268 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003156: Oct 2 14:22:00.268 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:233488F8
003157: Oct 2 14:22:00.268 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
003158: Oct 2 14:22:00.268 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
003159: Oct 2 14:22:00.272 UTC: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
Unexpected VoIPCodec Type :No Codec
SIP: -9568 Group (a= group line) attribute, level 65535 instance 1 not found.
003160: Oct 2 14:22:00.272 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
003161: Oct 2 14:22:00.272 UTC: //9568/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003162: Oct 2 14:22:00.272 UTC: //9568/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:23351278
003163: Oct 2 14:22:00.272 UTC: //9568/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
003164: Oct 2 14:22:00.272 UTC: //9568/1259CC729B4C/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
003165: Oct 2 14:22:00.300 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 15106297
003166: Oct 2 14:22:00.300 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 15617880
003167: Oct 2 14:22:00.300 UTC: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
ReqLine IP addr does not match with host IP addr
003168: Oct 2 14:22:00.300 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
003169: Oct 2 14:22:00.300 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003170: Oct 2 14:22:00.300 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:23348DC8
003171: Oct 2 14:22:00.300 UTC: //9567/1259CC729B4C/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
003172: Oct 2 14:22:01.760 UTC: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
003173: Oct 2 14:22:01.760 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003174: Oct 2 14:22:01.760 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:233525B8
003175: Oct 2 14:22:01.760 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: -9569 Attribute mid, level 1 instance 1 not found.
SIP: -9569 setup attribute, level 1 instance 1 not found.
SIP: -9569 connection attribute, level 1 instance 1 not found.
SIP: -9569 Attribute label, level 1 instance 1 not found.
SIP: -9569 a=framerate attribute, level 1 instance 1 not found.
003176: Oct 2 14:22:01.764 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003177: Oct 2 14:22:01.764 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:2334AFD0
003178: Oct 2 14:22:01.764 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
003179: Oct 2 14:22:01.764 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
003180: Oct 2 14:22:01.764 UTC: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
SIP: -9570 Group (a= group line) attribute, level 65535 instance 1 not found.
003181: Oct 2 14:22:01.768 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
003182: Oct 2 14:22:01.768 UTC: //9570/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003183: Oct 2 14:22:01.768 UTC: //9570/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:23351328
003184: Oct 2 14:22:01.768 UTC: //9570/133E11A09B53/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
003185: Oct 2 14:22:01.768 UTC: //9570/133E11A09B53/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
003186: Oct 2 14:22:01.792 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 31233236
003187: Oct 2 14:22:01.792 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 15617800
003188: Oct 2 14:22:01.792 UTC: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
003189: Oct 2 14:22:01.792 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
003190: Oct 2 14:22:01.792 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003191: Oct 2 14:22:01.792 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:23353060
003192: Oct 2 14:22:01.796 UTC: //9569/133E11A09B53/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
003193: Oct 2 14:22:17.780 UTC: //9570/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003194: Oct 2 14:22:17.780 UTC: //9570/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:233488A0
003195: Oct 2 14:22:17.780 UTC: //9570/133E11A09B53/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
SIP: Attribute mid, level 1 instance 1 not found.
SIP: setup attribute, level 1 instance 1 not found.
SIP: connection attribute, level 1 instance 1 not found.
SIP: Attribute label, level 1 instance 1 not found.
SIP: a=framerate attribute, level 1 instance 1 not found.
003196: Oct 2 14:22:17.780 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
003197: Oct 2 14:22:17.780 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
003198: Oct 2 14:22:17.780 UTC: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
003199: Oct 2 14:22:17.784 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
003200: Oct 2 14:22:17.784 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003201: Oct 2 14:22:17.784 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:2334E468
003202: Oct 2 14:22:17.784 UTC: //9569/133E11A09B53/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
003203: Oct 2 14:22:17.784 UTC: //9569/133E11A09B53/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
SIP: -9569 Group (a= group line) attribute, level 65535 instance 1 not found.
003204: Oct 2 14:22:17.796 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
003205: Oct 2 14:22:19.900 UTC: //9568/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003206: Oct 2 14:22:19.900 UTC: //9568/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:2334AF78
003207: Oct 2 14:22:19.900 UTC: //9568/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
003208: Oct 2 14:22:19.900 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
003209: Oct 2 14:22:19.900 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
003210: Oct 2 14:22:19.900 UTC: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
003211: Oct 2 14:22:19.900 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
003212: Oct 2 14:22:19.904 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003213: Oct 2 14:22:19.904 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:2334FFE8
003214: Oct 2 14:22:19.904 UTC: //9567/1259CC729B4C/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
003215: Oct 2 14:22:19.904 UTC: //9567/1259CC729B4C/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
SIP: -9567 Group (a= group line) attribute, level 65535 instance 1 not found.
003216: Oct 2 14:22:19.916 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
003217: Oct 2 14:22:27.425 UTC: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
003218: Oct 2 14:22:27.425 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003219: Oct 2 14:22:27.425 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:23353FD8
003220: Oct 2 14:22:27.425 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: -9571 Attribute mid, level 1 instance 1 not found.
SIP: -9571 setup attribute, level 1 instance 1 not found.
SIP: -9571 connection attribute, level 1 instance 1 not found.
SIP: -9571 Attribute label, level 1 instance 1 not found.
SIP: -9571 a=framerate attribute, level 1 instance 1 not found.
003221: Oct 2 14:22:27.425 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003222: Oct 2 14:22:27.425 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:23348378
003223: Oct 2 14:22:27.429 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
003224: Oct 2 14:22:27.429 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
003225: Oct 2 14:22:27.429 UTC: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
SIP: -9572 Group (a= group line) attribute, level 65535 instance 1 not found.
003226: Oct 2 14:22:27.429 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
003227: Oct 2 14:22:27.433 UTC: //9572/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003228: Oct 2 14:22:27.433 UTC: //9572/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:23349450
003229: Oct 2 14:22:27.433 UTC: //9572/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
003230: Oct 2 14:22:27.433 UTC: //9572/228A1D839B5A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
003231: Oct 2 14:22:27.457 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 41339333
003232: Oct 2 14:22:27.457 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
003233: Oct 2 14:22:27.457 UTC: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
003234: Oct 2 14:22:27.457 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
003235: Oct 2 14:22:27.457 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003236: Oct 2 14:22:27.457 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:23352F00
003237: Oct 2 14:22:27.457 UTC: //9571/228A1D839B5A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
003238: Oct 2 14:22:31.409 UTC: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
003239: Oct 2 14:22:31.413 UTC: //9573/24EA08159B61/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003240: Oct 2 14:22:31.413 UTC: //9573/24EA08159B61/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:23353BB8
003241: Oct 2 14:22:31.413 UTC: //9573/24EA08159B61/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: -9573 Attribute mid, level 1 instance 1 not found.
SIP: -9573 setup attribute, level 1 instance 1 not found.
SIP: -9573 connection attribute, level 1 instance 1 not found.
SIP: -9573 Attribute label, level 1 instance 1 not found.
SIP: -9573 a=framerate attribute, level 1 instance 1 not found.
003242: Oct 2 14:22:31.413 UTC: //9573/24EA08159B61/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003243: Oct 2 14:22:31.413 UTC: //9573/24EA08159B61/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:23347B38
003244: Oct 2 14:22:31.417 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
003245: Oct 2 14:22:31.417 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
003246: Oct 2 14:22:31.417 UTC: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
SIP: -9574 Group (a= group line) attribute, level 65535 instance 1 not found.
003247: Oct 2 14:22:31.417 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
003248: Oct 2 14:22:31.417 UTC: //9574/24EA08159B61/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003249: Oct 2 14:22:31.417 UTC: //9574/24EA08159B61/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:23353320
003250: Oct 2 14:22:31.417 UTC: //9574/24EA08159B61/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
003251: Oct 2 14:22:31.421 UTC: //9574/24EA08159B61/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
003252: Oct 2 14:22:31.445 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 31585746
003253: Oct 2 14:22:31.445 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
003254: Oct 2 14:22:31.445 UTC: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
003255: Oct 2 14:22:31.445 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
003256: Oct 2 14:22:31.445 UTC: //9573/24EA08159B61/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003257: Oct 2 14:22:31.445 UTC: //9573/24EA08159B61/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:2334F330
003258: Oct 2 14:22:31.445 UTC: //9573/24EA08159B61/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
003259: Oct 2 14:22:34.889 UTC: //9572/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003260: Oct 2 14:22:34.889 UTC: //9572/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:233549D0
003261: Oct 2 14:22:34.889 UTC: //9572/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
003262: Oct 2 14:22:34.889 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
003263: Oct 2 14:22:34.889 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
003264: Oct 2 14:22:34.889 UTC: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
003265: Oct 2 14:22:34.889 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
003266: Oct 2 14:22:34.893 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003267: Oct 2 14:22:34.893 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:233492F0
003268: Oct 2 14:22:34.893 UTC: //9571/228A1D839B5A/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:801
003269: Oct 2 14:22:34.893 UTC: //9571/228A1D839B5A/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
SIP: -9571 Group (a= group line) attribute, level 65535 instance 1 not found.
003270: Oct 2 14:22:34.905 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
003271: Oct 2 14:22:41.909 UTC: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
003272: Oct 2 14:22:41.913 UTC: //9575/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003273: Oct 2 14:22:41.913 UTC: //9575/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:23352980
003274: Oct 2 14:22:41.913 UTC: //9575/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: -9575 Attribute mid, level 1 instance 1 not found.
SIP: -9575 setup attribute, level 1 instance 1 not found.
SIP: -9575 connection attribute, level 1 instance 1 not found.
SIP: -9575 Attribute label, level 1 instance 1 not found.
SIP: -9575 a=framerate attribute, level 1 instance 1 not found.
003275: Oct 2 14:22:41.913 UTC: //9575/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003276: Oct 2 14:22:41.913 UTC: //9575/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:2334F750
003277: Oct 2 14:22:41.913 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
003278: Oct 2 14:22:41.917 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
003279: Oct 2 14:22:41.917 UTC: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
SIP: -9576 Group (a= group line) attribute, level 65535 instance 1 not found.
003280: Oct 2 14:22:41.917 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
003281: Oct 2 14:22:41.917 UTC: //9576/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003282: Oct 2 14:22:41.917 UTC: //9576/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:2334BC30
003283: Oct 2 14:22:41.917 UTC: //9576/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
003284: Oct 2 14:22:41.917 UTC: //9576/2B2C364D9B68/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
003285: Oct 2 14:22:41.945 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 41641827
003286: Oct 2 14:22:41.945 UTC: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
003287: Oct 2 14:22:41.945 UTC: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
003288: Oct 2 14:22:41.945 UTC: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
003289: Oct 2 14:22:41.945 UTC: //9575/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003290: Oct 2 14:22:41.945 UTC: //9575/2B2C364D9B68/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:2334E150
003291: Oct 2 14:22:41.945 UTC: //9575/2B2C364D9B68/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
IOS and HW are:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.3(3)M, RELEASE SOFTWARE (fc2)
Cisco CISCO2921/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Everyone's tags (2)
9 REPLIES 9
Beginner
Did you ever resolved this?
mine gives me that error in the log, but everything works.
Regards!
Highlighted
Beginner
No...still same error and
No...still same error and everything works also.
Contributor
The error code you are
The error code you are getting is 483 i.e. to many hops and its related to the Max-Forwards header in sip messages.
We need to look at sip messaging , please collect "debug ccsip message" for a call and send it across.
Beginner
Is there a command to edit
Is there a command to edit the Max-Forwards header, is this done on the CUBE router or on the CUCM that CUBE router is registered to?
Contributor
There is no specific command
There is no specific command which will modify max-forward header. If you want to do this on CUBE use SIP Profiles or if you want to do it on CUCM then use Normalization Scripts.
Beginner
I get the same error whenever
I get the same error whenever I make an outbound call on a dial peer that matches the pattern .T but on the same exact configured outbound dial peer that matches 10 digit I do not...
dial-peer voice 9998 voip
 description ** CUBE to PROVIDER **
 translation-profile outgoing PROVIDER-OUT
 destination-pattern .T
 session protocol sipv2
 session target sip-server
 no voice-class sip asserted-id
 no voice-class sip privacy-policy passthru
 voice-class sip dtmf-relay force rtp-nte
 no voice-class sip outbound-proxy
 voice-class sip profiles 1
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 9997 voip
 description ** Local CUBE to PROVIDER **
 destination-pattern [2-9]..[2-9]......
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
Engager
Can you please share the
Can you please share the output of debug ccsip messages of both working and non-working call....
Enthusiast
i am getting the same message
i am getting the same message "SIP: Trying to parse unsupported attribute at media level"
did you find the reason to generate this message ??
Rising star
Hi everyone,
Hi everyone,
The message is only informational, no harmless but is really annoying not be able to turn off. It just saying some CODECs or Features negociated are not supported at the far end.
Cisco Bug: CSCuv59697 - SIP Message "Trying to parse unsupported attribute at media level"
Last Modified
Sep 30, 2015
Product
Cisco IOS
Known Affected Releases
15.1(4)M1.1
Description (partial)
Symptom:
The error message "SIP: Trying to parse unsupported attribute at media level" was added to IOS in order to inform there are some unknown/unsupported media attributes (a=<attribute>, a=<attribute>:<value>) on the SDP.
There's no way to turn this message off. The output is not tied to any debug or syslog server event. However, the message is harmless and intended to be informational.
Conditions:
SIP process finds an unsupported media attribute within the SDP (a=<attribute>, a=<attribute>:<value>)
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Content for Community-Ad
August's Community Spotlight Awards
