Subscriber install version issue
bocasierra
We are running CUCM 6.1.5su2 (6.1.5.12900-7) and need to add a new subscriber. We cannot upgrade directly from 6.1 to 6.1.5su2 during installation. This is according to the Readme file - and I did try with no luck.
So I would like to install using the 6.1 DVD and provide the 6.1.5 iso as the upgrade/patch during the installation process and then after the install completes do a second upgrade using the 6.1.5su2 iso. Will this procedure work?
matt
Rob Huffman
Hi Matt,
I'm thinking you'll need to jump to an interim 6.1(x) build (not 6.1(5)) as
the patch during install portion of this build. Have a look and
you can see that even the "base" 6.1(5) seems to have the same
Direct Upgrade considerations;
Table 17     Supported Cisco Unified Communications Manager Upgrades for Release 6.1(5x)
6.1(5)SU2
6.1(5)SU1
6.1(5)1
System Version
6.1.5.12900-7
6.1.5.11900-13
6.1.5.10000-10
Release Date
Oct 6 2010
May 17 2010
Feb 4 2010
Standard Support
Direct upgrade:
6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3)
Direct upgrade:
Direct upgrade:
6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e), 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade using DMA:
none
none
4.3(2), 4.2(3), 4.1(3)
Note Refer to the Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades concerning upgrades from ESs.
1 Cisco does not support using the "Upgrade during install" option with 5.1(3x) DVDs and the 6.1.5 tar.gz upgrade patch. See CSCte78503 for more details.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp189359
Cheers!
Rob
Thanks - yes it looks like 6.1(3) would work as an intermediate release. But will it let a 6.1(3) subscriber join an existing 6.1(5) cluster without doing any harm to the database? Assuming it does let it join, and I then do a post-install upgrade 6.1(5)su2, will I need to do a repair or reset on the database to get replication back in synch?
matt
Rob Huffman
Hi Matt,
Great questions!
To be honest I'm not sure how the Publisher and replication will handle
the "wrong version" Sub. I've never had to build one up with these steps.
You can't be the first person who has had this type of conundrum, but if
it were me I would open a TAC case with all the details just to be safe.
Cheers!
Rob
PS: I know this doesn't help you, but this type of case highlights the need for
current build DVD's. You can order new builds as they come out via PUT just
to mitigate this type of issue.
