11-18-2010 06:47 PM - edited 03-16-2019 02:00 AM
I am trying to install Call Manager subscriber
8.0.3 on Cisco MCS 7835 I3 server but it keep on failing with critical error
execution of script
"/usr/local/bin/base_scripts/sd_ifconfig -eth0 -ethtool "autoneg on" ... failed with return code 256
Check licensing
Check connectivity
I tested with hard code the speed and duplex
11-19-2010 09:05 AM
The error is indicating an issue with the NIC, check the following
1) Did BIOS recognize the NIC card ? erify the LED on the NIC and what are you seeing
2) Is your switch mode configured as access (switchport mode access )
3) If the speed and duplex are hard coded on the switch they must match with the server.
Lakshmi
08-08-2014 10:10 AM
In addition to what Laskhmi has said, do you have Node license for this subscriber installed in PUB , if I go with "Check Licensing" message.
regds,
aman
08-08-2014 09:19 AM
I'm getting the same error when tryint to install 8.0.3 onto a version 10.5 .ova. Where you ever able to figure this problem out?
Thank you..
