01-29-2016 12:11 AM - edited 03-17-2019 05:39 AM
In a CUCM cluster of two servers(6.0.1.20003) the subscriber server stayed offline for 2-3 months.
When they decided to use it again, only NTP and SSH services seems started.
admin:utils service list
Requesting service status, please wait...
System NTP [STARTED]
System SSH [STARTED]
Service Manager is running
Getting list of all services
Service Manager is currently busy, please try again in a few minutes
Primary Node =false
When trying to start any service we have the following message:
admin:utils service start A Cisco DB
Service Manager Response list for list request is NULL
admin:utils service start Cisco Tomcat
Is there anything to do to start services and use the server again?
Thank you very much.
Solved! Go to Solution.
01-29-2016 12:37 AM
If you have bootable file for this version, easiest way is to rebuild the sub as the working pub will replicate the current database.
Rajan
01-29-2016 02:18 AM
As Rajan mentioned earlier, the simplest method is to rebuild the Sub and it will sync all configs from Pub. No need to try recovery in your scenario. However, worth reading the Tech Note Shared by Deepak.
You need reachability between PuB and SuB during installation. The Sub needs to authenticate with security password with Sub to resume installation.
I suggest you ship the server to remote location along with installation DVD, provide iLO reachability to server and perform remote installation. Or if you can configure remote subnet in your local office for temp installation of SuB that will work. Avoid installation at one site and change the IP later on the new site
01-29-2016 12:37 AM
Rajan
01-29-2016 01:10 AM
Hello Rajan and thank you for the reply,
I have a 4 month old backup of the subscriber server.
Is it good to install cucm from scratch on the sub server and then apply the backup?
Is it necessary that the sub server can reach pub server during installation?
I am saying that because those servers are at a different town.
So i am thinking of doing the work at my place and then send sub server back to them.
Thanks again.
01-29-2016 01:26 AM
if you apply that old backup, it will create DB replication issues later. So I would say better you rebuild the sub and let the pub take care of replication. Also connection to Pub is mandatory during subscriber rebuild as it will authenticate security password with Publisher during installation in order to be part of the same cluster.
Rajan
01-29-2016 02:18 AM
01-29-2016 03:36 AM
Rebuild is not simpler than running the Recovery for sure and that should be the first thing before trying to go for a rebuild. But since there is indeed no Recovery Disk available for version 6, in fact nothing is available on CCO for this version. Best option would indeed now be to go ahead with the rebuild of subscriber server.
Publisher reachability is definitely important during the time of subscriber installation, without it the installation will not go through. Do not try the restore option as it will indeed create lot of DB issues.
Deepak
02-01-2016 12:13 AM
Hello Deepak,
Yes, I will go on and have the subscriber rebuild.
I'll send client the installation disk and guide a person on customer's site for the procedure.
01-29-2016 12:39 AM
Try to power it down gracefully and then bring it up. Switch the machine down using:
utils system shutdown
Once the machine is shut down completely, remove power cable from back of the server, put it back again and then power it on. Wait for 15 - 20 minutes and check if the services come up. If not, then it will be worth to run a repair using the Recovery Disk, follow the below document for procedure to do that:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118948-technote-cucm-00.html
Deepak
01-29-2016 12:58 AM
Hello Deepak,
I have already shut the server, remove the power cable and start it back again, unfortunately with the same result. The link you posted is for VM servers?
01-29-2016 01:07 AM
It can be followed for MCS server as well. The only thing different you will need to do is that, burn the Recovery Software on a disk and then insert it inside the CD/DVD drive of the MCS server and follow the instructions as mentioned in the doc.
Deepak
01-29-2016 01:24 AM
