supervisory disconnect
mkashifashraf
Dear All,
I have CISCO2921-CME-SRST/K9 bundle, with ISM-SRE-300 Unity module.
CCME 8.6, CUE 8.6 versions.
I'm facing a problem that outside caller make the call to our network, Auto Attendant receive the call & transfer as per required extension.
Our inside IP Phone is ringing, if no one is there & outside call cut the line(call).
still Inside IP Phone is ringing continuesly, I tried supervisory disconnect but facing the same problem any one have the configuration
of the parameteres of PSTN (STC Saudi Arabia) to configure it properly.
or someone knows any other solution related to this issue??
Please reply soon
regards,
Muhammad Kashif Ashraf
paolo bevilacqua
If if it doesn't work, you've set the wrong parameters. You should confirm them with recording and a frequency analisys. That is explained in many threads of the same subject.
Try this configuration..
voice class custom-cptone STC
dualtone disconnect
frequency 425
cadence 500 500
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone leavetone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice port parameters..
supervisory disconnect dualtone mid-call
supervisory custom-cptone STC
no battery-reversal
echo-cancel coverage 32
cptone BR
timeouts call-disconnect 3
timeouts ringing 5
timeouts wait-release 5
timing hookflash-out 500
Dear Owais,
sorry for the late update.
I tried above configuration but the result is same. call is not disconnected.
also i tried 1 command "timing sup-disconnect 500"
but no effect.
Please reply soon
any update? did you solve the issue? i am facing the same problem... help really appreciated.
