Support for DNS configuration setting "A-Record" has ended
my provider has changed their service and no longer support the DNS configuration setting "A-Record".
So my CISCO IP Phone doesn't work anymore. On the display the message is: "Checking DNS".
Do you know what I have to change to bring it back to work?
Greetings
... was it, no idea why, but now it works.
Thanks for your help
10 Replies 10
balaji.bandi
May be you need  setup own DNS Service on the Router or in the same DHCP Server - make sure Phones able to resolve the DNS name ?
BB
Hm, good question. However, I am no IT-Expert.
The provider wrote: From now on, the so-called SRV query is used for address resolution
They are saying I have to change the SIP Port to 0. However, it doesn't seem to work.
Do I have to change something in the "SIP" Window?
It is a German provider. Here the link (sadly only in German): https://geschaeftskunden.telekom.de/hilfe-und-service/hilfe-themen/hilfe-rund-um-internet-und-dsl/telefonieanpassung?wt_mc=alias_telefonieanpassung
Not sure if we followed correctly - what was
A-Record before service provider removed ? can you give full domain ?
BB
What do you mean with "full domain"?
I don’t see in the shared screenshots any place where you configure a name record. Would you mind to please share this?
Response Signature
If you know where I can look it up, sure ;).
How would I know that, it's your system? If I would venture on a guess it would be under Ext 1 tab.
Response Signature
Infos I can find:
That’s the DNS server. That only sets where your system should direct its name lookup. There must be some configuration somewhere that sets where your system should register, that’s the configuration your service provider instructs you to change.
Response Signature
