%SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Gi4/34, operational port trust state is now untrusted.
sarathcisco2013
.Feb  5 09:56:44.310 utc: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Gi4/34, operational port trust state is now untrusted.
ios - cat4500e-universalk9.SPA.03.05.02.E.152-1.E2.bin
Model -
cisco WS-C4506-E (MPC8572) processor (revision 6) with 2097152K bytes of physical memory.
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Last reset from PowerUp
2 Virtual Ethernet interfaces
244 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Switchport configuration
interface GigabitEthernet4/34
description *** 35-A ***
switchport access vlan 50
switchport mode access
switchport voice vlan 60
switchport port-security maximum 2
switchport port-security mac-address sticky
switchport port-security mac-address sticky 1803.73da.7381
switchport port-security mac-address sticky 189c.5daa.71fd vlan voice
auto qos voip cisco-phone
storm-control broadcast level 20.00
qos trust device cisco-phone
spanning-tree portfast
service-policy input AutoQos-4.0-Cisco-Phone-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
Please anybody can help on this -
suggest if any configuration issue is there.
10 Replies 10
balaji.bandi
If this was working phone and  you see suddenly developed  the issue on that port. Try to swap with new patch lead and try.
if this is new one you trying to configure, post the QOS configuration from switch.
another thing look thing sticky MAC address matches with the device other note.(may be not related to this issue).
BB
this is existing phone.
Try Swapping the Patch Lead and Advise how it go ?
BB
this is not happening for single port, its random .
Upgrade the firmware of the switch.
is there any bug,
when i had  search for the bugs, it showed ios is stable.
if any bugs can you suggest which version i have to upgrade.
  1. This version was released back in March 2014.   That's almost five years.
  2. Go HERE.  This is a long list of security vulnerabilities that affects 3.5.2.
  3. IOS-XE version ends with a "2".  That's the 2nd release.  That's still a buggy release.
  4. Finally, the last version for the 3.5 train is 3.5.3.  Ever wondered why there's no more after that?
 Another thing:  Post the complete output to the command "sh interface Gi4/34".
Ok if this random to many ports, we need to look for the bug as suggested by @Leo Laohoo upgrade to new OS.
Try reboot the device and see if that fix the issue - but suggested for upgrade.
BB
done an ios upgrade waiting for the status
Was this ever resolved?
