datacenter
Beginner
Switching equipment congestion
Hello guys!
1st of all i want to say that i researched a lot about the error bellow and i still getting same problem even afeter apllying the recommended workarounds.
631178: Mar 18 12:38:48.910: ISDN BR0/1/0 CCd: ie_in_out_msg: message 0x84 ie = 25 ie_allowed =0
631179: Mar 18 12:38:48.910: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x50
    Cause i = 0x82AA - Switching equipment congestion
We have a branch that uses Siemens as a analogical pabx, while trying to connect from here we got this error in q931 debug.
The call gets dropped in the moment that the person answers the call... it seems like there is any kind of codec negotiation problem but i'm not sure.
Our CUCM runs in 8.5 version and i'm trying to get additional info from RTMT once it can be CUCM sending disconnection and not only the router right?
The problem is that we've upgraded our cucm recently and the VLT (voice log translator) is not recognizing the logs i get from RTMT and i cant understand the whole thing without it.
When i try to load calllogs it says that "No log messages in selected file(s)".
Tried other app's too but no way... im just openin RTMT, selecting Tools > Trace & Log Central > Collect files: Select Call Manager, next next... thats it! (the log file is attached)
Opening via Excel i get it this way:
2013/04/09   08:43:02.894|CC|SETUP|21585265|21585266|55476914|35122734|35122734
2013/04/09   08:43:03.716|CC|SETUP|21585267|21585268|55476914|734|734
2013/04/09   08:43:08.042|CC|REJECT|21585267|21585268|55476914|734|734|47
Well, this is not that clear but i think i made my point.
Thanks in advance!
Daniel
1 ACCEPTED SOLUTION
Ok,
From these logs, We can see that the problem is not with the ISDN leg of the call. The call is actually been disconnected by CUCM and the reason is cause 47..This is usually a media capabilities issue..
What is the codec configured on  Dial-peer 37 ? (from the log it looks like its G729)
What is the region between the gateway and the IP phone that made the call 55476914. If the codec on dial-peer 37 is G729 and the region is set to G711 then you will have this issue...
Can you send your sh run..
also do another test call and send
debug h225 asn1
debug h245 asn1
debug voip ccapi inout
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
8 REPLIES 8
Looking at the debugs, your gateway is sending the disconnect..
Can you send the output of
'show voice dsp detail'
Thanks!
Bellow sh voice dsp detailed of our branch's router.
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
edsp 0001 01 g711ulaw  0.1 IDLE  50/0/1.1
edsp 0002 01 g729r8 p  0.1 IDLE  50/0/2.1
edsp 0003 01 g711ulaw  0.1 IDLE  50/0/3.1
edsp 0004 01 g729r8 p  0.1 IDLE  50/0/4.1
edsp 0005 01 g729r8 p  0.1 IDLE  50/0/5.1
edsp 0006 01 g729r8 p  0.1 IDLE  50/0/6.1
edsp 0007 01 g729r8 p  0.1 IDLE  50/0/7.1
edsp 0008 01 g729r8 p  0.1 IDLE  50/0/8.1
edsp 0009 01 g729r8 p  0.1 IDLE  50/0/9.1
edsp 0010 01 g729r8 p  0.1 IDLE  50/0/10.1
edsp 0011 01 g729r8 p  0.1 IDLE  50/0/11.1
edsp 0012 01 g729r8 p  0.1 IDLE  50/0/12.1
edsp 0013 01 g729r8 p  0.1 IDLE  50/0/13.1
edsp 0014 01 g729r8 p  0.1 IDLE  50/0/14.1
edsp 0015 01 g729r8 p  0.1 IDLE  50/0/15.1
edsp 0016 01 g729r8 p  0.1 IDLE  50/0/16.1
edsp 0017 01 g729r8 p  0.1 IDLE  50/0/17.1
edsp 0018 01 g711ulaw  0.1 IDLE  50/0/18.1
edsp 0019 01 g729r8 p  0.1 IDLE  50/0/19.1
edsp 0020 01 g729r8 p  0.1 IDLE  50/0/20.1
edsp 0021 01 g729r8 p  0.1 IDLE  50/0/21.1
edsp 0022 01 g729r8 p  0.1 IDLE  50/0/22.1
edsp 0023 01 g729r8 p  0.1 IDLE  50/0/23.1
edsp 0024 01 g729r8 p  0.1 IDLE  50/0/24.1
edsp 0025 01 g729r8 p  0.1 IDLE  50/0/25.1
edsp 0026 01 g729r8 p  0.1 IDLE  50/0/26.1
edsp 0027 01 g729r8 p  0.1 IDLE  50/0/27.1
edsp 0028 01 g729r8 p  0.1 IDLE  50/0/28.1
edsp 0029 01 g729r8 p  0.1 IDLE  50/0/29.1
edsp 0030 01 g729r8 p  0.1 IDLE  50/0/30.1
edsp 0031 01 g729r8 p  0.1 IDLE  50/0/31.1
edsp 0032 01 g729r8 p  0.1 IDLE  50/0/32.1
edsp 0033 01 g729r8 p  0.1 IDLE  50/0/33.1
edsp 0034 01 g729r8 p  0.1 IDLE  50/0/34.1
edsp 0035 01 g729r8 p  0.1 IDLE  50/0/35.1
edsp 0036 01 g729r8 p  0.1 IDLE  50/0/36.1
edsp 0037 01 g729r8 p  0.1 IDLE  50/0/37.1
edsp 0038 01 g729r8 p  0.1 IDLE  50/0/38.1
edsp 0039 01 g729r8 p  0.1 IDLE  50/0/39.1
edsp 0040 01 g729r8 p  0.1 IDLE  50/0/40.1
edsp 0041 01 g729r8 p  0.1 IDLE  50/0/41.1
edsp 0042 01 g729r8 p  0.1 IDLE  50/0/42.1
edsp 0043 01 g729r8 p  0.1 IDLE  50/0/43.1
edsp 0044 01 g729r8 p  0.1 IDLE  50/0/44.1
edsp 0045 01 g729r8 p  0.1 IDLE  50/0/45.1
edsp 0046 01 g729r8 p  0.1 IDLE  50/0/46.1
edsp 0047 01 g729r8 p  0.1 IDLE  50/0/47.1
edsp 0048 01 g729r8 p  0.1 IDLE  50/0/48.1
edsp 0049 01 g729r8 p  0.1 IDLE  50/0/49.1
edsp 0050 01 g729r8 p  0.1 IDLE  50/0/50.1
edsp 0051 01 g729r8 p  0.1 IDLE  50/0/51.1
edsp 0052 01 g729r8 p  0.1 IDLE  50/0/52.1
edsp 0053 01 g729r8 p  0.1 IDLE  50/0/53.1
edsp 0054 01 g729r8 p  0.1 IDLE  50/0/54.1
edsp 0055 01 g729r8 p  0.1 IDLE  50/0/55.1
edsp 0056 01 g729r8 p  0.1 IDLE  50/0/56.1
edsp 0057 01 g729r8 p  0.1 IDLE  50/0/57.1
edsp 0058 01 g729r8 p  0.1 IDLE  50/0/58.1
edsp 0059 01 g729r8 p  0.1 IDLE  50/0/59.1
edsp 0060 01 g729r8 p  0.1 IDLE  50/0/60.1
edsp 0061 01 g729r8 p  0.1 IDLE  50/0/61.1
edsp 0062 01 g729r8 p  0.1 IDLE  50/0/62.1
edsp 0063 01 g729r8 p  0.1 IDLE  50/0/63.1
edsp 0064 01 g729r8 p  0.1 IDLE  50/0/64.1
edsp 0065 01 g729r8 p  0.1 IDLE  50/0/65.1
edsp 0066 01 g729r8 p  0.1 IDLE  50/0/66.1
edsp 0067 01 g729r8 p  0.1 IDLE  50/0/67.1
edsp 0068 01 g729r8 p  0.1 IDLE  50/0/68.1
edsp 0069 01 g729r8 p  0.1 IDLE  50/0/69.1
edsp 0070 01 g729r8 p  0.1 IDLE  50/0/70.1
edsp 0071 01 g729r8 p  0.1 IDLE  50/0/71.1
edsp 0072 01 g729r8 p  0.1 IDLE  50/0/72.1
edsp 0073 01 g729r8 p  0.1 IDLE  50/0/73.1
edsp 0074 01 g729r8 p  0.1 IDLE  50/0/74.1
edsp 0075 01 g729r8 p  0.1 IDLE  50/0/75.1
edsp 0076 01 g729r8 p  0.1 IDLE  50/0/76.1
edsp 0077 01 g729r8 p  0.1 IDLE  50/0/77.1
edsp 0078 01 g729r8 p  0.1 IDLE  50/0/78.1
edsp 0079 01 g729r8 p  0.1 IDLE  50/0/79.1
edsp 0080 01 g729r8 p  0.1 IDLE  50/0/80.1
edsp 0081 01 g729r8 p  0.1 IDLE  50/0/81.1
edsp 0082 01 g729r8 p  0.1 IDLE  50/0/82.1
edsp 0083 01 g729r8 p  0.1 IDLE  50/0/83.1
edsp 0084 01 g729r8 p  0.1 IDLE  50/0/84.1
edsp 0085 01 g729r8 p  0.1 IDLE  50/0/85.1
edsp 0086 01 g729r8 p  0.1 IDLE  50/0/86.1
edsp 0087 01 g729r8 p  0.1 IDLE  50/0/87.1
edsp 0088 01 g729r8 p  0.1 IDLE  50/0/88.1
edsp 0089 01 g729r8 p  0.1 IDLE  50/0/89.1
edsp 0090 01 g729r8 p  0.1 IDLE  50/0/90.1
edsp 0091 01 g729r8 p  0.1 IDLE  50/0/91.1
edsp 0092 01 g729r8 p  0.1 IDLE  50/0/92.1
edsp 0093 01 g729r8 p  0.1 IDLE  50/0/93.1
edsp 0094 01 g729r8 p  0.1 IDLE  50/0/94.1
edsp 0095 01 g729r8 p  0.1 IDLE  50/0/95.1
edsp 0096 01 g729r8 p  0.1 IDLE  50/0/96.1
edsp 0097 01 g729r8 p  0.1 IDLE  50/0/97.1
edsp 0098 01 g729r8 p  0.1 IDLE  50/0/98.1
edsp 0099 01 g729r8 p  0.1 IDLE  50/0/99.1
edsp 0100 01 g729r8 p  0.1 IDLE  50/0/100.1
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510  001 01 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 02 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 03 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 04 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 05 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 06 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 07 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 08 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 09 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 10 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 11 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 12 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 13 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 14 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 15 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  001 16 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 01 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 02 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 03 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 04 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 05 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 06 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 07 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 08 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 09 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 10 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 11 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 12 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 13 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 14 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 15 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  002 16 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 01 g711ulaw      28.3.8 busy  idle      0  0 0/1/0     00    0  18311/18898
C5510  003 02 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 03 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 04 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 05 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 06 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 07 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 08 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 09 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 10 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 11 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 12 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 13 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 14 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 15 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  003 16 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 01 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 02 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 03 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 04 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 05 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 06 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 07 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 08 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 09 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 10 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 11 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 12 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 13 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 14 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 15 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  004 16 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 01 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 02 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 03 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 04 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 05 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 06 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 07 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 08 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 09 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 10 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 11 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 12 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 13 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 14 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 15 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  005 16 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 01 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 02 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 03 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 04 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 05 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 06 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 07 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 08 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 09 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 10 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 11 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 12 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 13 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 14 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 15 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  006 16 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 01 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 02 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 03 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 04 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 05 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 06 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 07 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 08 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 09 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 10 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 11 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 12 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 13 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 14 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 15 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  007 16 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 01 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 02 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 03 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 04 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 05 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 06 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 07 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 08 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 09 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 10 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 11 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 12 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 13 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 14 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 15 None          28.3.8 idle  idle      0  0                 0          0/0
C5510  008 16 None          28.3.8 idle  idle      0  0                 0          0/0
                           *DSP SIGNALING CHANNELS*
------------------------END OF FLEX VOICE CARD 0 ----------------------------
Can we try and reset the dsps...
Use this command...
test dsp device 0 all reset
after the reset
send debug isdn q931
I assume that this gateway is an h323 gaterway connected to cucm and you have the E1 going to the PBX
cucm---h323--gateway---e1--pbx
Yes, you're right.
We have here in Brazil our CUCM and one branch in Portugal using a gateway running as h323 with an e1 BRI connection to Siemens PBX.
Resetted dsp's and stil, here it follow the logs of both debugs you asked:
000283: *Apr  9 15:53:30.008: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid sp
i for destaddr=62.28.245.250, prot=50, spi=0xF059AD46(4032408902), srcaddr=62.48.235.113, input inte
rface=FastEthernet0/3/0.2
000284: *Apr  9 15:53:30.032: //-1/00E8EA9D8826/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=55476914
   ----- ccCallInfo IE subfields -----
   cisco-ani=55476914
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=734
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
000285: *Apr  9 15:53:30.032: //-1/00E8EA9D8826/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x6A0FB38C, Call Info(
   Calling Number=55476914,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Present
ation=Allowed),
   Called Number=734(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=37, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=31
000286: *Apr  9 15:53:30.032: //-1/00E8EA9D8826/CCAPI/ccCheckClipClir:
   In: Calling Number=55476914(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowe
d)
000287: *Apr  9 15:53:30.032: //-1/00E8EA9D8826/CCAPI/ccCheckClipClir:
   Out: Calling Number=55476914(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allow
ed)
000288: *Apr  9 15:53:30.032: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000289: *Apr  9 15:53:30.032: :cc_get_feature_vsa malloc success
000290: *Apr  9 15:53:30.032: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000291: *Apr  9 15:53:30.032:  cc_get_feature_vsa count is 1
000292: *Apr  9 15:53:30.032: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000293: *Apr  9 15:53:30.032: :FEATURE_VSA attributes are: feature_name:0,feature_time:1826992416,fe
ature_id:20
000294: *Apr  9 15:53:30.032: //31/00E8EA9D8826/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=55476914(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=
Allowed),
   Called Number=734(TON=Unknown, NPI=Unknown))
000295: *Apr  9 15:53:30.032: //31/00E8EA9D8826/CCAPI/cc_process_call_setup_ind:
   Event=0x6A5250D0
000296: *Apr  9 15:53:30.032: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 734
000297: *
RTPTMAI022#Apr  9 15:53:30.032: //31/00E8EA9D8826/CCAPI/ccCallSetContext:
   Context=0x7407FAAC
000298: *Apr  9 15:53:30.032: //31/00E8EA9D8826/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 31 with tag 37 to app "_ManagedAppProcess_Default"
000299: *Apr  9 15:53:30.032: //31/00E8EA9D8826/CCAPI/ccCallProceeding:
000300: *Apr  9 15:53:30.032: //31/00E8EA9D8826/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=6700, Params=0x74080FBC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
000301: *Apr  9 15:53:30.032: //31/00E8EA9D8826/CCAPI/ccCheckClipClir:
d)
000302: *Apr  9 15:53:30.036: //31/00E8EA9D8826/CCAPI/ccCheckClipClir:
ed)
000303: *Apr  9 15:53:30.036: //31/00E8EA9D8826/CCAPI/ccCallSetupRequest:
   Destination Pattern=[67].., Called Number=734, Digit Strip=TRUE
000304: *Apr  9 15:53:30.036: //31/00E8EA9D8826/CCAPI/ccCallSetupRequest:
   Calling Number=55476914(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Redirect Number=, Display Info=
   Account Number=55476914, Final Destination Flag=TRUE,
   Guid=00E8EA9D-7939-4116-8826-35010AFB0102, Outgoing Dial-peer=6700
000305: *Apr  9 15:53:30.036: //31/00E8EA9D8826/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=55476914
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=734
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
000306: *Apr  9 15:53:30.036: //31/00E8EA9D8826/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x6A5477BC, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=55476914,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Pas
   Called Number=734(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=6700, Call Count On=FA
LSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
000307: *Apr  9 15:53:30.036: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000308: *Apr  9 15:53:30.036: :cc_get_feature_vsa malloc success
000309: *Apr  9 15:53:30.036: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000310: *Apr  9 15:53:30.036:  cc_get_feature_vsa count is 2
000311: *Apr  9 15:53:30.036: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000312: *Apr  9 15:53:30.036: :FEATURE_VSA attributes are: feature_name:0,feature_time:1826992864,fe
ature_id:21
000313: *Apr  9 15:53:30.036: //32/00E8EA9D8826/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
000314: *Apr  9 15:53:30.036: //32/00E8EA9D8826/CCAPI/ccCallSetContext:
   Context=0x74080F6C
000315: *Apr  9 15:53:30.036: //31/00E8EA9D8826/CCAPI/ccSaveDialpeerTag:
000316: *Apr  9 15:53:30.036: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calli
ng num 55476914
000317: *Apr  9 15:53:30.036: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0002 callID = 0x8004 swi
tch = basic-net3 interface = Network
000318: *Apr  9 15:53:30.040: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x02
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0081, '55476914'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '734'
000319: *Apr  9 15:53:30.120: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x82
        Channel ID i = 0x89
                Exclusive, B1
000320: *Apr  9 15:53:30.124: //32/00E8EA9D8826/CCAPI/cc_api_call_proceeding:
   Interface=0x6A5477BC, Progress Indication=NULL(0)
000321: *Apr  9 15:53:30.228: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8  callref = 0x82
000322: *Apr  9 15:53:30.228: //32/00E8EA9D8826/CCAPI/cc_api_call_alert:
   Interface=0x6A5477BC, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255)
000323: *Apr  9 15:53:30.228: //32/00E8EA9D8826/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
000324: *Apr  9 15:53:30.228: //31/00E8EA9D8826/CCAPI/ccCallAlert:
000325: *Apr  9 15:53:30.228: //31/00E8EA9D8826/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
000326: *Apr  9 15:53:30.228: //32/00E8EA9D8826/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
000327: *Apr  9 15:53:30.228: //31/00E8EA9D8826/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=31
000328: *Apr  9 15:53:30.228: //32/00E8EA9D8826/CCAPI/cc_api_get_called_ccm_detected:
000329: *Apr  9 15:53:30.228: //31/00E8EA9D8826/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
RTPTMAI022#
000330: *Apr  9 15:53:31.760: ISDN BR0/1/0 Q931: RX <- CONNECT pd = 8  callref = 0x82
        Connected Number i = 0x0180, '734'
000331: *Apr  9 15:53:31.764: ISDN BR0/1/0 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x02
000332: *Apr  9 15:53:31.764: //32/00E8EA9D8826/CCAPI/cc_api_call_connected:
   Interface=0x6A5477BC, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
000333: *Apr  9 15:53:31.764: //32/00E8EA9D8826/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
000334: *Apr  9 15:53:31.768: //31/00E8EA9D8826/CCAPI/ccConferenceCreate:
   (confID=0x741E3A30, callID1=0x1F, gcid=0-0-0-0, tag=0x0)
000335: *Apr  9 15:53:31.768: //32/00E8EA9D8826/CCAPI/ccConferenceCreate:
   (confID=0x741E3A30, callID2=0x20, gcid=0-0-0-0, tag=0x0)
000336: *Apr  9 15:53:31.768: //31/00E8EA9D8826/CCAPI/ccConferenceCreate:
   Conference Id=0x741E3A30, Call Id1=31, Call Id2=32, Tag=0x0
000337: *Apr  9 15:53:31.768: //31/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
000338: *Apr  9 15:53:31.768: cc_api_get_xcode_stream : 4702
000339: *Apr  9 15:53:31.768: //31/00E8EA9D8826/CCAPI/cc_api_bridge_done:
   Conference Id=0x2, Source Interface=0x6A0FB38C, Source Call Id=31,
   Destination Call Id=32, Disposition=0x0, Tag=0x0
000340: *Apr  9 15:53:31.768: //32/00E8EA9D8826/CCAPI/cc_api_bridge_done:
   Conference Id=0x2, Source Interface=0x6A5477BC, Source Call Id=32,
   Destination Call Id=31, Disposition=0x0, Tag=0xFFFFFFFF
000341: *Apr  9 15:53:31.768: //31/00E8EA9D8826/CCAPI/cc_generic_bridge_done:
000342: *Apr  9 15:53:31.768: //31/00E8EA9D8826/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2, Destination Call Id=32)
000343: *Apr  9 15:53:31.768: //32/00E8EA9D8826/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2, Destination Call Id=31)
000344: *Apr  9 15:53:31.768: //32/00E8EA9D8826/CCAPI/cc_api_caps_ind:
   Destination Interface=0x6A0FB38C, Destination Call Id=31, Source Call Id=32,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
000345: *Apr  9 15:53:31.768: //32/00E8EA9D8826/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
000346: *Apr  9 15:53:31.768: //31/00E8EA9D8826/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
000347: *Apr  9 15:53:31.768: //32/00E8EA9D8826/CCAPI/cc_api_get_called_ccm_detected:
RTPTMAI022#
000348: *Apr  9 15:53:31.768: //31/00E8EA9D8826/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
000349: *Apr  9 15:53:31.768: //31/00E8EA9D8826/CCAPI/ccCallNotify:
000350: *Apr  9 15:53:31.768: //32/00E8EA9D8826/CCAPI/cc_api_get_called_ccm_detected:
000351: *Apr  9 15:53:31.772: //31/00E8EA9D8826/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2, Call Id1=31, Call Id2=32
000352: *Apr  9 15:53:32.732: //31/00E8EA9D8826/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x6A0FB38C, Call Id=31
000353: *Apr  9 15:53:32.732: //31/00E8EA9D8826/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
000354: *Apr  9 15:53:32.732: //31/00E8EA9D8826/CCAPI/ccConferenceDestroy:
   Conference Id=0x2, Tag=0x0
000355: *Apr  9 15:53:32.732: //31/00E8EA9D8826/CCAPI/cc_api_bridge_drop_done:
000356: *Apr  9 15:53:32.732: //32/00E8EA9D8826/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=31, Disposition=0x0, Tag=0x0
000357: *Apr  9 15:53:32.732: //31/00E8EA9D8826/CCAPI/cc_generic_bridge_done:
000358: *Apr  9 15:53:32.736: //31/00E8EA9D8826/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
000359: *Apr  9 15:53:32.736: //31/00E8EA9D8826/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
000360: *Apr  9 15:53:32.736: //31/00E8EA9D8826/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
000361: *Apr  9 15:53:32.736: //32/00E8EA9D8826/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000362: *Apr  9 15:53:32.736: //32/00E8EA9D8826/CCAPI/ccCallDisconnect:
000363: *Apr  9 15:53:32.736: //32/00E8EA9D8826/CCAPI/cc_api_get_transfer_info:
000364: *Apr  9 15:53:32.740: //31/00E8EA9D8826/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6A0FB38C, Tag=0x0, Call Id=31,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
000365: *Apr  9 15:53:32.740: //31/00E8EA9D8826/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
000366: *Apr  9 15:53:32.740: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000367: *Apr  9 15:53:32.740: :cc_free_feature_vsa freeing 6CE5B118
000368: *Apr  9 15:53:32.740: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000369: *Apr  9 15:53:32.740:  vsacount in free is 1
000370: *Apr  9 15:53:32.740: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x02
000371: *Apr  9 15:53:32.848: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x82
000372: *Apr  9 15:53:32.852: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x02
000373: *Apr  9 15:53:32.856: //32/00E8EA9D8826/CCAPI/cc_api_call_disconnect_done:
RTPTMAI022#Disposition=0, Interface=0x6A5477BC, Tag=0x0, Call Id=32,
000374: *Apr  9 15:53:32.856: //32/00E8EA9D8826/CCAPI/cc_api_call_disconnect_done:
000375: *Apr  9 15:53:32.856: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000376: *Apr  9 15:53:32.856: :cc_free_feature_vsa freeing 6CE5B2D8
000377: *Apr  9 15:53:32.856: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000378: *Apr  9 15:53:32.856:  vsacount in free is 0
Thanks again
Ok,
debug h225 asn1
debug h245 asn1
Daniel,
Did you get a chance to look at my post. Is your issue resolved now?
You were right!
I took a look on your post and we discovered a problem in our transcoder.
I've just fixed the codec to g729 in the incoming dialpeers of the router as our location in CUCM was already fixed to it and it solved the problem.
Thank you, rating now.
Dear all,
I have same problem, can you inform me about the solution? thank you
Content for Community-Ad
Spotlight Awards 2021
