Beginner
SX20 provisioning failed GET Edge config:HTTP code=401
SX20 is in Singapore,cucm core is in Beijing.
I have put rootCA cert in the SX20 already.
Set NTP and DNS(local) already.
Username and password was imported from LDAP.
SX20 can not registered.
Everyone's tags (3)
3 REPLIES 3
Rising star
Re: SX20 provisioning failed GET Edge config:HTTP code=401
wentao jiang,
I recommend you post this to the Cisco Support Community for technical assistance.
https://supportforums.cisco.com/
Kelli Glass
Moderator for Cisco Customer Communities
Beginner
ok thank you
Highlighted
Contributor
You can try cisco Collab Edge Validator in Cisco Collaboration Solution Analyzer
https://cway.cisco.com/tools/CollaborationSolutionsAnalyzer/
Content for Community-Ad
July's Community Spotlight Awards
