04-15-2013 06:45 AM - edited 03-16-2019 04:48 PM
Hi all,
I have registered a new SX20 my CUCM 9 cluster all working well apart from outbound calls to the PSTN via H323 gateway, inbound calls work fine but outbound drop after one ring. I believe this is down to the SX20 trying to G722 for calls even thought my dial peers are G711, i have tried registering a transcoders to the gateway with no joy. is there anyway i can force the SX20 to G711 when calling the PSTN??
ISDN Q931 error is
Cause i = 0x80AF - Resource unavailable, unspecified
i see from debug voip ccappi inout
000711: Apr 15 13:25:07.554: //107/00364413AB06/CCAPI/cc_api_caps_ack:
Destination Interface=0x2BE05010, Destination Call Id=108, Source Call Id=107,
Caps(Codec=g722-64(0x10000000), Fax Rate=FAX_RATE_14400(0x80), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8743)
Matt
04-15-2013 07:26 AM
Mathew,
If you have registeed the device to CUCM, then you can use region settings to set the codec to G711..Configure the region between the device and the h323 gateway to G711..Then ensure that the inbound dial-peer on your h323 gateway has either voice-class codec with g711 on it or configure the dial-peer to use G711..
If you have configured a xcoder..and its not working then you need to look at the inbound dial-peer on your h323 gateway..what the codec set to? for a traditional xcoder to work one leg of it has to be G711..unless you use a universal transcoder which can conver between non G711 codecs
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-15-2013 07:39 AM
Both Deivces sit in the same region which has the Max Audio Bit Rate set to 64 kbps (G.722, G.711) which allows both G722 and G711.
on my inbound dial-peer voip dial-peer from the cucm i use this voice class
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
Matt
04-15-2013 08:24 AM
You have two options..
1. Disable G722 in CUCM service parameters
Browse to System>Enterprise Parameters
Search for Advertise G.722 Codec
Disable the Advertisement of G.722 Codec
2. Use the new Audio codec preferecnce list feature in CUCM 9
Create a new Audio codec preferecnce list, in that list Ensure G711 is above G722, assign the list to your region
test again..
Please send debug voip ccapi inout and debug isdn q931 if you still have issues
