Highlighted
Contributor
System design, help - only analogue cabling
Hi All
We have a site whereby it is impossible for us to install any new cabling, we can only use the analogue telephony cabling they have in place now, there are about 20 analogue phones on site, basic reception phone and voicemail only.
We need to replace the old analogue phone system with something else.
Knowing we cannot replace the cabling, what options do we have?
I was thinking maybe a cucme with a VG310?
Are these compatible? would I get enough functionality?
Cheers
Everyone's tags (1)
7 REPLIES 7
Highlighted
Hall of Fame Master
Re: System design, help - only analogue cabling
I've heard of some customers in similar situation successfully using the Phybridge switches.  I myself never deployed these, but supposedly they work as advertised:
https://marketplace.cisco.com/catalog/solution/90769?pid=95056
Highlighted
VIP Collaborator
VG 310 is supported with CUCME. Here is the compatibility guide:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme126spc.html
Regarding functionality, you need to check what features you are looking and what features are supported with CUCME and VG 310 integration. You can go through supplementary services features guide for FXS Ports:
https://www.cisco.com/c/en/us/td/docs/ios/voice/fxs/configuration/guide/15_1/fxs_15_1_cg_book.html
The other option is to use Cisco 4000 Series Router with SM-X-24FXS/4FXO. SM-X-24FXS/4FXO is supported with CUCME. In this case you don't have to maintain two different equipment's. Below URL provides the list of supplementary analog features available on 4000 Series ISRs using FXS and FXO service modules:
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-739991.html
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Highlighted
Rising star
If your current phone system is digital it likely offers more functionality especially for the console station. Patton and other companies make devices to run Ethernet over single pair voice grade copper , coax , etc. Some phones like the 8861 also run over WiFi, and Jabber etc on a PC. I gather if you had the funding for that you’d upgrade the cable plant.
Highlighted
Hall of Fame Master
This is where Phybridge comes into play, you can run POE over old analog/digital cables when re-wiring with CAT5/6 is not an option.
Highlighted
Contributor
Hi There
So would I just plug the 21 from the patch panel into the phybridge unit, then plug the cucme into the network and the phones will register like a normal phone over ethernet etc?
Highlighted
Hall of Fame Master
Correct, you can use Cisco IP Phones over insufficient cabling with the switch.
Highlighted
Hall of Fame Community Legend
Wireless handset.
Content for Community-Ad
FusionCharts will render here
