09-19-2011 09:56 AM - edited 03-16-2019 07:04 AM
I had installed a CUCM cluster with 2 servers, after I installed the license file I got the following warning:
System is operating on insufficient licenses. Please upload additional license files.
I noticed the problem is that only one node is allowed in the license I Installed.
What I need to do in order to add the other node license to the configuration?
Thanks for any help you can give me about it.
09-19-2011 10:50 AM
You need to upload another license node if you have it or buy another license node so you get the license.
All that is in the .lic files so unless you have the necessary node, DLUs and feature licenses you can expect this kind of problems.
Another solution is to disable the CCM service on the extra-nodes and only run it in the amount of nodes you have licensed.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
09-20-2011 07:23 AM
Hi javalenc ,
Thanks for your answer, do you know what is the SKU or part number related to a CUCM node license.
Greetings
09-20-2011 09:49 AM
What version of CUCM?
