System returned to ROM by bus error at PC 0x357F0454
iptsupport
Level 4
Level 4
Hello ,
I have router 2911
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
After an unexpected reboot it says:
before reset the router we can't got incoming/outgoing calls .
After we made reset ,the problem was solved.
we need to know why the router crashed?
thanks
Leo Laohoo
Most likely due to a memory leak.
Recommend to upgrade the IOS.
