We implented a new virtual fax server and it's connected to my VG2911 with an H.323 connection between the fax server and gateway.
Faxes from the east coast are fine but when offices from my west coast offices fax I see the call connect to the fax server but then it gets dropped.
Is there anything specific I can look for?
Mike
Do you have your GW configured for T.38? Are you using protocol based or NSE based T.38?
Can you post relevant config?
What if you call it do you get fax tones?
Chris
version 15.0
service timestamps debug datetime localtime
service timestamps log datetime localtime
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 30000000
no logging console
aaa session-id common
clock timezone EST -5
clock summer-time EST recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
no ipv6 cef
ip source-route
ip cef
ip domain
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 ls-redundancy 2 hs-redundancy 0 fallback none
h323
no call service stop
session transport udp
voice class h323 1
h225 timeout tcp establish 3
license udi pid CISCO2901/K9
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
controller T1 0/0/1
interface GigabitEthernet0/0
ip address
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:23
dial-peer voice 100 pots
destination-pattern .T
incoming called-number .
direct-inward-dial
port 0/0/0:23
forward-digits all
dial-peer voice 103 voip
description ***Main Fax Server***
preference 1
destination-pattern
session target ipv4:
voice-class h323 1
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
gatekeeper
shutdown
OK, so you are using protocol based, good.
Why is session target on your voip dial peer blank? This does not point to anything. You need to point it to your fax server's IP address.
HTH,
Chris
I removed them..
I have them in my actual config... I have faxes working but I have problems when faxes come in from the west coast to the east coast. I see the call connect on the VG and connect on the fax server but then it times out and the west coast offices get an erro message that states "poor line connection"
Where are the west coast faxes come in to? Are they coming into another GW and then are sent to this one?
Can you post config of that GW as well as "sh controller T1" from both?
Chris
My fax server resides in NJ. All faxes come into NJ and then get sent via email. They come directly to this gateway there is nothing inbetween.
