Hello everyone
We are implementing a CUCM ver 10.5 platform.
This Ip telephony system uses a cisco 2901 ver Version 15.3(3) as voice gateway to access PSTN and another company's Telephony system (I will call it "companyB").
To get access to companyB's Telephony system, we configured our router as MGCP gateway connected to other Cisco 2901 router through a CAS T1 connection ( using 12 channels)
Here is the configuration we implemented on our router:
isdn switch-type primary-ni
controller T1 0/0/0
cablelength long 0db
ds0-group 0 timeslots 1-12 type e&m-wink-start
description VOICE T1 to companyB
voice-port 0/0/0:0
auto-cut-through
output attenuation 3
ccm-manager mgcp
mgcp
mgcp call-agent CUCM 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
We configured this MGCP gateway on our CUCM but when we tested this connection we don't get registration of this circuit on our CUCM.
On router we see that mgcp is UP, but we are unable to activate the 12 T1 CAS ports as "MGCP endpoints".
Although when we run: "sh voice port 0/0/0:0" on router we see this output:
Router#sh voice port 0/0/0:0
recEive and transMit Slot is 0, Subslot is 0, Sub-unit is 0, Port is 0
Type of VoicePort is E&M
Operation State is DORMANT
Administrative State is UP
IN OUT
PORT CH SIG-TYPE OPER STATUS STATUS TIP RING
0/0/0:0 01 e&m-wnk dorm idle idle
0/0/0:0 02 e&m-wnk dorm idle idle
0/0/0:0 03 e&m-wnk dorm idle idle
0/0/0:0 04 e&m-wnk dorm idle idle
0/0/0:0 05 e&m-wnk dorm idle idle
0/0/0:0 06 e&m-wnk dorm idle idle
0/0/0:0 07 e&m-wnk dorm idle idle
0/0/0:0 08 e&m-wnk dorm idle idle
0/0/0:0 09 e&m-wnk dorm idle idle
0/0/0:0 10 e&m-wnk dorm idle idle
0/0/0:0 11 e&m-wnk dorm idle idle
0/0/0:0 12 e&m-wnk dorm idle idle
Could you please tell me is I am misconfiguring or missing something for this connection?
Any help will be appreciated.
Thanks in advanced
Enrique Villasana
Solved! Go to Solution.
Can you post the output of below command:
sh ccm-manager
1) mgcp call-agent CUCM 2427 service-type mgcp version 0.1 <<< Have you configured ip address where you have typed CUCM, if not try that
2) Have you configured the device name/domain correctly?
3) Make sure you have below command under your serial interface:
"isdn bind-l3 ccm-manager"
4) Also I would suggest bind MGCP to the interface which can reach CUCM:
mgcp bind control source-int Gx/y
mgcp bind media source-in Gx/y
Once you are done with the configs, type in no mgcp, mgcp
Let me know how you go with above.
-Terry
Please rate all helpful posts
sh ccm-manager
-Terry
Thanks for answering.
Here you have:
MyRouterw#sh ccm-manager
MGCP Domain Name: MyRouterw.grupogloria.corp
Priority Status Host
Primary Registered CUCM (192.168.118.12)
First Backup None
Second Backup None
Current active Call Manager: 192.168.118.12
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 07:03:50 AST May 29 2015 (elapsed time: 00:00:07
Last MGCP traffic time: 07:03:50 AST May 29 2015 (elapsed time: 00:00:07
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
FAX mode: cisco
Configuration Error History:
MyRouterw#
My new mgcp config:
ccm-manager mgcp
mgcp
mgcp call-agent PRSDSJ118012 2427 service-type mgcp version 0.1
mgcp bind control source-interface GigabitEthernet0/0.118
mgcp bind media source-interface GigabitEthernet0/0.118
dial-peer voice 1 pots
service mgcpapp
port 0/0/0:0
I did "no mgcp/mgcp" commands but the gateway keeps in a "Rejected" state on my CUCM.
I run "debug mgcp packet: and here is the output:
May 29 12:56:27.458: MGCP Packet received from 192.168.118.12:2427--->
200 152026447
May 29 12:56:42.458: MGCP Packet sent to 192.168.118.12:2427--->
NTFY 152026448 *@MyRouter.mydomain.com MGCP 0.1
X: 0
O:
May 29 12:56:42.458: MGCP Packet received from 192.168.118.12:2427--->
200 152026448
May 29 12:56:57.458: MGCP Packet sent to 192.168.118.12:2427--->
NTFY 152026449 *@MyRouter.mydomain.com MGCP 0.1
X: 0
O:
Only one thing I have to add , I am getting "slip secs/Errored Secs" on controller:
MyRouter#sh controllers t1 0/0/0
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long 0db
Description: VOICE T1 to PERU
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info FPGA Rev: 08121917, FPGA Type: PRK4
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (3 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
5198 Line Code Violations, 8 Path Code Violations
54 Slip Secs, 2 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
53 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 317 Unavail Secs
Data in Interval 2:
83 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
83 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 2 15 minute intervals):
5198 Line Code Violations, 8 Path Code Violations,
137 Slip Secs, 2 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
136 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 317 Unavail Secs
I HTH
Thanks again !!!!
Enrique
Kindly paste a snapshot of your port and gateway config cucm side.
In logs ,I can see MyRouter.mydomain.com and show ccm-manager shows MGCP Domain Name: MyRouterw.grupogloria.corp.
can u share the snapshot of config from Call manager as asked by moyo?
regds,
aman
Hi Terry, moyo oyegunle and Aman Soi!!!
Thanks for your interest.
The root cause was a mistype on "dial-peer voice 1 pots"
service mgcpap <------ ERROR instead of proper command: "service MGCPAPP"
port 0/0/0:0
AFTER this change the gateway got registration and we start to call with this gateway!!!
I selected Terry answer because I have not configured recommended commands.
THANKS AGAIN
Enrique Villasana
Good problem got resolved.
thanks for update.
regds,
aman
No worries, thanks for the update - actually I was going to add the step to confirm the dial-peer step as well but got distracted and somehow missed that. Anyways see you around.
-Terry
