T1 line configured on different Serial port
Amafsha1
Level 2
Level 2
Hello, I've noticed something recently that I don't understand.
We use MGCP.
Serial0/0/0:0 is in the below output.  This is where our T1 is configured.
Serial0/0/0:0 is up, line protocol is up
Hardware is DSX1
Description: DS1IT to ISP MPLS
Internet address is 63.x.x.42/30
MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
reliability 255/255, txload 25/255, rxload 60/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 34385
Queueing strategy: Class-based queueing
Output queue: 6/1000/34385 (size/max total/drops)
5 minute input rate 365000 bits/sec, 67 packets/sec
5 minute output rate 153000 bits/sec, 66 packets/sec
52293166 packets input, 4144144677 bytes, 0 no buffer
Received 197884 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
48430758 packets output, 684817026 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
1 carrier transitions
Yet, why is it that our configurations are on Serial0/0/1:23 ?
interface Serial0/0/1:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
When I do show int below on that interface of Serial0/0/1:23, I get empty counters.  why is that?
 Serial0/0/1:23 is down, line protocol is down
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
Yup, it's configured for a "channel-group". That's data ONLY.
controller T1 0/0/0
clock source line independent
cablelength long 0db
channel-group 0 timeslots 1-24
For T1/E1 CCS, you would need a "pri-group" and for T1/E1 CAS you would need a "ds-group". Only with these two there would be "voice-ports" which are important for VOICE.
7 Replies 7
R0g22
Serial0/0/0:0 >> does not look to be like a voice circuit. Even if it is, its NOT CCS. T1 is not necessarily for voice only. Can you send an output for "show run | s contro|voice-port" ?
Serial0/0/1:23 >> is configured for voice BUT the L1/L2 stat is DOWN so this circuit is not functioning currently
You're right it is not a voice circuit, it is used for Data.  Here is the output you asked for
controller T1 0/0/0
controller T1 0/0/1
pri-group timeslots 1-24 service mgcp
control-plane
voice-port 0/1/0
trunk-group OUTGOING
echo-cancel coverage 64
timing hookflash-out 50
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/0/1:23
controller T1 0/0/0
Thank you, sorry I'm not too familiar with voice.  So where does the voice traffic go than?
That's fine, no need to apologise. They should be what I believe to be FXO port -
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
Do a "show inven" and check the slot/subslot for an FXO port on their. Then match that to the voice-port. The convention is slot/subslot/port (ports are non-canonical from an IOS perspective i.e. right to left and always start at 0).
#sh inv
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw , Hw Revision: 1.0"
PID: CISCO2911/K9 , VID: V07 , SN: FTX1805AL95
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1 , VID: V01 ,
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V04 ,
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16 , VID: V01 ,
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 16 Channels"
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC , VID: V05 ,
So you're saying that the PRI here is being used for data, and we have FXO ports that are being used for voice?
Correct. You can further confirm that if you see any dial-peers configured and they have a "trunkgroup OUTGOING" configured under them and not shut.
Do a "show run | s -peer".
