T1 - Trunk Groups
jcartier
Beginner
Beginner
Hi Group,
I'm involved in a scenario where I have a partial T1 dropping in 10 DS0 voice channels and my requirement is for me to be accepting incoming calls from the bottom and placing outgoing calls from the top.
How would I go about doing this? I'm looking at some documentation and the concept of using Trunk Groups appears to possibly be it...
12 REPLIES 12
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Is that PRI, or CAS that you have ?
p.bevilacqua,
The connection is a PRI.
PRI defaults to the anti-glare hunt scheme you described, so nothing needs to be done about.
Please remember to rate useful posts with the scrollbox below.
What about if it was a T1 CAS?
Same IIRC. But in that case, you would be able to use alternative using trunk-group.
