Tandem CDR Question
DOUG DAVIDSON
Level 5
Level 5
I have a simple question regarding Tandem Calls, and I have probably over looked the answer. When looking at Traffic Summary, I understand that Tandem calls are one that came in on one gateway and left via another gateway. My questions is are both legs counted in the count? As an example, a call comes in and is forwarded back out, does that count as one Tandem call or are the inbound and outbound each counted?
CUCM 8.5.1
Thanks in advance,
Doug
Rob Huffman
Hi Doug,
I believe each Tandem call should be counted as 1 in the Traffic Summary. It's a single record
with gateway 1 as the Orig. and gateway 2 as the Dest.
Cheers!
Rob
