TAPS Configurations Docs CM 6.x
pstryer
Beginner
Beginner
Could someone point me to some good configuration docs on how to setup TAPS from start to finish on CM 6.x
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Working with the Cisco Unified Communications Manager Auto-Register Phone Tool
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_1_1/t15taps.html
java
if this helps, please rate
java
Hello - Thank you for the link, but I have been to this paper and it is really not a great doc it only tells part of the story.
1. From this paper it sounds like you can not run TAPS from the CM server any more like you could from v4.x, is that true? Sounds like you have to have CRS server on a windows platform to use TAPS in 6.x
if that is true do the customers have to buy CRS or is it a give me since they have to have it to run TAPS?
2. This paper does not talk about how to conifure the TAPS Pilot number or anything of the configurations. Is there a paper that talks about how to setup the TAPS Pilot number and the reset of the settings needed to use TAPS?
Thanks again for your help
Cheers
Paul
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hey Paul,
I always hate being the bearer of bad news but, you are correct :( TAPS will require a seperate CRS/IPCC server in each case. Of course this used to be able to be a built-in function using a co-resident CCM/CRS build but no longer now that CCM 5.x and 6.x are using Linux. This box will have to be purchased.
Here is some of the relevant config info.
Starting @ Page 369;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_2_3/bat.pdf
Hope this helps!
Rob
Recognize Your Peers
