TCL in Voice Gateway
AbbasDadou
I tried to configure tcl script that will match an incoming VOIP dial-peer. But the script couldn't be loaded.
and i get the below error
%CALL_CONTROL-6-APP_NOT_FOUND: Application XXXX in dial-peer 12 not found. Handing callid 4415 to the alternate app .
dial-peer voice 12 voip
service XXXX
voice-class codec 1
session protocol sipv2
session target ipv4:XXX.XXX.XXX.XXX
incoming called-number XXXXXXXXXXXX
Can you please advice
Best Regards,
Abbas
paolo bevilacqua
Have you configured correctly the application? Check "debug voice application script" to be sure.
