Highlighted
Beginner
TEHO Calls from China to Brazil
Hello Guys,
We are trying to implement TEHO calls between an PBX on China and Brazil without luck as the diagram bellow illustrates.
So that we have:
1. PBX connected to a H323 Voice Gateway.
2. Signaling comes to a cluster in Brazil.
3. On the inbound CSS of the gateway i have created a new CSS giving access to the DN and E164 route pattern partition.
4. Call is sent to the MGCP gateway in Brazil.
Although DNA shows me the call comming perfectly fine when i "csim" from the China Gateway (It's not in production yet) any of the phones in Brazil are ringing. Any ideas?
2 REPLIES 2
Highlighted
Hall of Fame Cisco Employee
I'd do a real call and not use CSIM, do that, and then come back with the results.
If it still doesn't work, explain what you see/hear on the phone and if it fails, chances are it's related to call routing being wrong somewhere along the way, you might need to add/remove digits as your dial plan requires.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Highlighted
Advocate
Please give us more details on your case, if possible let us know what exactly is going on
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Content for Community-Ad
