ā04-02-2013 12:54 PM - edited ā03-16-2019 04:34 PM
Im having a problem with an ISDN circuit that goes from TEI_assigned to Awaiting_Establisment , Im hoping someone can help me.
Here is the q921 info:
Apr 2 18:11:57.738: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:11:57.738: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:11:58.738: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:11:59.738: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:00.738: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:07.750: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:12:07.750: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:08.750: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:09.750: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:10.750: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:17.758: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:12:17.758: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:18.758: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:19.758: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:20.758: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:27.771: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:12:27.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:28.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:29.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:30.771: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:37.787: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:12:37.787: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:38.787: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:39.787: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:40.787: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:47.795: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:12:47.795: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:48.795: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:49.795: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:50.795: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:57.816: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:12:57.816: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:58.816: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:12:59.816: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:00.816: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:07.836: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:13:07.836: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:08.836: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:09.836: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:10.836: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:17.848: ISDN Se0/1/0:23 Q921: L2_EstablishDataLink: sending SABME
Apr 2 18:13:17.848: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:18.848: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:19.848: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Apr 2 18:13:20.848: ISDN Se0/1/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
ISDN Serial0/1/0:23 interface
dsl 1, interface ISDN Switchtype = primary-ni
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 27
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
T1 0/1/0 is up.
Applique type is Channelized T1
Cablelength is long 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20090408, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320. T1 0/1/0 is up.
No alarms detected.
Solved! Go to Solution.
ā04-02-2013 01:58 PM
Contact telco as the circuit is not working, no reply from CO.
If they tell you it is working and the problem is on your side, invite them on your premises to show you a working call with their testing equipment.
ā04-02-2013 03:50 PM
Not sure what it was but once the carrier side bounced the circuit it came right up..... wish I had called them 2 weeks ago.
Thanks for your help
ā04-02-2013 04:01 PM
Thank you for the nice rating and good luck!
