11-05-2009 02:32 AM - edited 03-15-2019 08:21 PM
I have encourtered issue inserting 7975 phones using BAT. The error message is below
"Telecaster table may only reference devices that support Cisco Unified IP Phone Services."
I have delete the services on the template and I have no issues on previous attempts to insert the 7975 phones.
Any ideas?
Solved! Go to Solution.
11-05-2009 08:12 AM
Remove whatever directory URL you have configured on the Phone Template and try again
CSCsv27394
TELECASTER Error 3500 when using BAT Phone Template
java
if this helps, please rate
http://www.cisco.com/go/pdihelpdesk
11-05-2009 08:12 AM
CSCsv27394
java
