Telneting from cucm 7.x
r.boloor.rao
Beginner
Beginner
I am troublehsooting a simple call scenario ; CCM ---h.323---GW--PRI.
Incoming calls were failing from PRI to CCM.  I tried to telnet from the Gateway to CCM on port 1720 to see if CCM is listening on that port.
ciscogw#telnet ciscoccm 1720
Trying ciscoccm, 1720 ... Open
[Connection to ciscoccm closed by foreign host]
ciscogw#
This gateway is at remote site and connected to central site via MPLS network.
Is there any way I can test similar connection from CCM to gateway ?.
William Bell
Advisor
Advisor
Not directly. You could set up a route pattern to the gateway in CUCM and then place a call from a phone to the gateway. In parrallel, you can run a network trace on CUCM to see the actual conversation (or lack thereof) between the CUCM and the voice gateway.
You can initiate a trace from the CLI of the CUCM system and you can filter on the IP address of the voice gateway:
admin: utils network capture file mygwtrace count 100000 size all host ip
A small write up I did on the process:
http://www.netcraftsmen.net/resources/blogs/networktraces-cisco-uc.html
Anyway, the point is that using a network trace to monitor connections between the GW and the CUCM is probably a more useful and informative approach.
HTH.
Bill
please rate helpful posts
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Recognize Your Peers
