05-29-2018 07:38 AM - edited 03-17-2019 12:54 PM
Hi Guys,
In specific site about my Customer I am verifing in RTMT that there are many temporary failure code 41 and only occur in inbound calls. I read any posts about this, but, is not clear for me what the cause about this possible problem. Any have idea about this?
Wilson
05-29-2018 07:42 AM
Hi there
Temp code 41 generally means that one or more of the resources needed to complete the call is not available.
Like any issues with DSPs, bearer channels, ip connectivity are resources that can cause this
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
05-29-2018 07:49 AM
Hi Cisco Rath!,
Thanks a lot for Your contact. In the first time I don´t see problem with this issues.
Wilson
05-29-2018 09:01 AM
Hi there
Can you share the topology here? Whats the router/IOS being used ?
Also share the debugs for failed calls
Hope this Helps
Cheers
Rath!
06-04-2018 07:17 AM
Hi Cisco Rath!
What Your doubt about Topology? About the debug, unfortunatelly my profile don´t have access to configuration terminal to collect the logs. About the IOS version, follow:
System image file is "flash:c2951-universalk9-mz.SPA.154-3.M5.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Wilson
06-04-2018 08:13 AM
Hi there
Sorry if I was not not clear to you. You mentioned the issue is occurring only on a specific site inbound calls. How is the site connected. I assume this is a remote site over WAN and its connected to a centralized CUCM. Whats the gateway you use and the protocol running. SIP/MGCP/H323.
The best bet is to share debugs for the failed calls from the gateway.
Hope this Helps
Cheers
Rath!
06-04-2018 01:43 PM
Hi Cisco Rath!
Ok, no problem. This site is working with SIP and is remote site connected by WAN with the main site that have CUCM centralized.
Wilson
