05-04-2015 02:04 PM - edited 03-17-2019 02:54 AM
Hey all,
Hoping I can get a quick direction on this.....
We are upgrading our call center servers and need to point a few test toll free numbers.
I have already created a test sip trunk....here's where it all gets muddy for me. What do I need to do to route 4 specific toll free numbers to hit this specific sip trunk instead of going to our current one?
Any docs and verbal guidance would be appreciated.
Thanks in advance all!
Solved! Go to Solution.
05-04-2015 04:23 PM
OK, then simply configure the exact digits you're expecting from the toll free number in the route pattern using that SIP trunk with.
This is no different from outbound calls, if you have a pattern that is a better match over one that matches multiple numbers, it will always be preferred as we use best match routing.
05-04-2015 03:56 PM
Inbound calls??
Outbound calls??
Via CUCM??
05-04-2015 04:14 PM
Inbound via CUCM 8.0 over a T1, sip trunk is the connection between CUCM and call center server.
05-04-2015 04:23 PM
05-04-2015 04:27 PM
Awesome, I'll give that a try tonight.
Thanks Jaime.
05-04-2015 04:36 PM
Take your test indial range and point it out your test sip trunk, using the usual Route Pattern>RG in CUCM
05-04-2015 06:45 PM
Ok, so here's what i did....
I created the following >>> RG with new server as member>RL with the new RG as member>RP
We already have a RP of 5[1-9]XXX which matches the DNIS of the 4 toll free numbers we are using for this test, so I just went ahead and created an exact match RP of 59796. (I'll create the other 3 if I can get this to work)
Before I created all this, the call went to our sales dept like designed. After creating it, now I get a "this number has been disconnected" message. What did I miss?
05-05-2015 10:46 AM
Hey all...
Finally got this to work....had to reset the RG and RL once everything was configured. Apparently it takes a reset for the settings to propagate.
Thanks for your help.
