1428
Highlighted
Beginner
TFTP error on 3925 intergrated voice router
We have a 3925 intergrated voice router that prompts this error  cmapp_sccp_tftp_download_file: Unable to get configuration file size tftp://x.x.x.x/SKIGxxxxxx.cnf.xml, rc=-2
It gives the IP to our call manager then a mac address of analog gatway and extension pertaining to cnf.xml. The error runs when the  router  is connected to the network and also when it is not connected to the network. I have looked in the Cisco bug toolkit did not find a bug that was related to the issue. I check the tftp in the call manager there is no file of that type which there should not be. We have 3925s voice routers already registered to the call manager. Voice router information below:
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
System image file is "flash:c3900e-universalk9-mz.SPA.152-4.M2.bin"
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE200/K9 with 1797120K/300032K bytes of memory
4 REPLIES 4
Highlighted
Rising star
Are you using the 3925 as a CME? If yes, could you please post the config.
Highlighted
No, we are not using as CME.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.03.26 11:13:02 =~=~=~=~=~=~=~=~=~=~=~=
XXXXXXXX#
XXXXXX#term len 0
XXXXXXXX#sh run
Building configuration...
Current configuration : 14446 bytes
! Last configuration change
! NVRAM
! NVRAM
version 15.2
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname XXXXXXX
boot-start-marker
boot system flash:c3900e-universalk9-mz.SPA.152-4.M2.bin
boot-end-marker
card type t1 0 0
logging buffered 16384
enable secret 4 DJsu7i99xp.Xzvkf3epKdaTCS5CUguxaCh2jhXROMZ.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
ip cef
no ip domain lookup
ip domain name textron.com
no ipv6 cef
isdn switch-type primary-dms100
voice-card 0
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice translation-rule 1
rule 1 /3451/ /918005336093/
voice translation-rule 2
rule 1 /^\(4...\)$/ /XXXXXX\1/
rule 2 /^\(6...\)$/ /XXXXXX\1/
voice translation-profile 5-digit-dial
translate called 1
voice translation-profile pstn-in
translate called 2
application
global
service alternate default
license udi pid
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module pvdm 0/2
vtp domain BHAMA
vtp mode transparent
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
description
controller T1 0/0/1
description
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Loopback0
ip address
interface Loopback11
description
ip address
interface GigabitEthernet0/0
description
ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description
ip address 1
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
description
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address .* plan isdn type national
no cdp enable
interface Serial0/0/1:23
description
no ip address
encapsulation hdlc
no cdp enable
router eigrp 1
network 10.0.0.0
redistribute connected
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tacacs source-interface Loopback11
logging trap notifications
logging facility local1
logging source-interface Loopback11
logging host
logging host
logging host
logging host
logging host
access-list 18 permit
access-list 86 permit
access-list 89 permit
nls resp-timeout 1
cpd cr-id 1
snmp-server community
snmp-server ifindex persist
snmp-server trap-source Loopback11
snmp-server locatiON
snmp-server contact
snmp-server system-shutdown
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps flowmon
snmp-server enable traps transceiver all
snmp-server enable traps ds1
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps gatekeeper
snmp-server enable traps xgcp
snmp-server enable traps license
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps flash insertion removal
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps ds3
snmp-server enable traps entity-sensor threshold
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps adslline
snmp-server enable traps vdsl2line
snmp-server enable traps c3g
snmp-server enable traps icsudsu
snmp-server enable traps envmon
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps energywise
snmp-server enable traps vstack
snmp-server enable traps mac-notification
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps nhrp nhs
snmp-server enable traps nhrp nhc
snmp-server enable traps nhrp nhp
snmp-server enable traps nhrp quota-exceeded
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vtp
snmp-server enable traps bstun
snmp-server enable traps dlsw
snmp-server enable traps ipsla
snmp-server enable traps stun
snmp-server enable traps bfd
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps mpls rfc ldp
snmp-server enable traps mpls ldp
snmp-server enable traps pw vc
snmp-server enable traps ipmobile
snmp-server enable traps snasw alert isr topology cp-cp port link dlus
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps dsp video-usage
snmp-server enable traps dsp video-out-of-resource
snmp-server enable traps ethernet cfm alarm
snmp-server enable traps rf
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server enable traps mpls vpn
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server enable traps voice
snmp-server enable traps dnis
snmp-server host
snmp-server host
snmp-server host
tacacs-server host
tacacs-server host
tacacs-server host
tacacs-server host
tacacs-server key
control-plane
voice-port 0/0/0:23
voice-port 0/0/1:23
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.244.200.33 10.227.210.33
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold bind Loopback11
ccm-manager config server X.X.X.X. X.X.X.X X.X.X.X
ccm-manager config
ccm-manager sccp local Loopback11
mgcp
mgcp call-agent X.X.X.X. 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability mf-package
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package line-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp fax t38 nsf 000000
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback11
mgcp bind media source-interface Loopback11
mgcp profile default
sccp ccm X.X.X.X identifier 1 priority 1 version 7.0
sccp ccm X.X.X.X identifier 2 priority 2 version 7.0
sccp ccm X.X.X.X identifier 3 priority 3 version 7.0
sccp ip precedence 3
sccp ccm group 1
bind interface Loopback11
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 2 register Amarillo_XCODE
associate profile 3 register Amarillo_MTP
associate profile 1 register Amarillo_CNFB
switchback method graceful
switchback interval 8
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 20
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 8
dspfarm profile 3 mtp
codec g711ulaw
codec pass-through
maximum sessions hardware 42
maximum sessions software 200
dial-peer voice 1 pots
translation-profile incoming pstn-in
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
destination-pattern 9[2-9]11
port 0/0/0:23
forward-digits 3
dial-peer voice 11 pots
preference 1
port 0/0/1:23
forward-digits 3
dial-peer voice 12 pots
destination-pattern 911
port 0/0/0:23
forward-digits 3
dial-peer voice 13 pots
preference 1
port 0/0/1:23
forward-digits 3
dial-peer voice 20 pots
destination-pattern 9[2-9].........
port 0/0/0:23
forward-digits 10
dial-peer voice 21 pots
preference 1
port 0/0/1:23
forward-digits 10
dial-peer voice 30 pots
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
dial-peer voice 31 pots
preference 1
port 0/0/1:23
forward-digits 11
dial-peer voice 40 pots
destination-pattern 9011T
port 0/0/0:23
prefix 011
dial-peer voice 41 pots
preference 1
port 0/0/1:23
prefix 011
dial-peer voice 50 pots
direct-inward-dial
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address X.X.X.X port 2000
max-ephones 700
max-dn 1400 octo-line
system message primary Operating in SRST mode
system message secondary In SRST mode
transfer-pattern .T
voicemail XXXXXXXXXXXX
translation-profile incoming 5-digit-dial
call-forward pattern .T
call-forward busy XXXXXXX
call-forward noan XXXXXXXX timeout 10
time-zone 8
banner exec ^C
^C
banner login ^C
******************* WARNING NOTICE *******************
^C
line con 0
exec-timeout 15 0
password
line aux 0
exec-timeout 15 0
password
line vty 0 4
exec-timeout 60 0
password
transport input all
line vty 5 924
exec-timeout 60 0
password
transport input all
scheduler allocate 20000 1000
ntp access-group
ntp server
ntp server
ntp server
ntp server
Highlighted
Why are you using "ccm-manager sccp local Loopback11"
If it's not in use , i would suggest remove this command. this is the source of your problem.
Aditya Gupta
Highlighted
Actually, the culprit is the 'ccm-manager config' command.  This command is instructing the router to contact the CUCM TFTP server to download the port configuration.  All this does is automatically create the dial-peers that MGCP uses on the router.  Many times, I see engineers manually create the dial-peers and manually enter the 'application MGCPAPP' command.  If you properly configure CUCM and the 'ccm-manager config' command, you don't have to do that.  However, looking at your config, I don't see MGCP doing anything at all. Is this device defined with CUCM as an MGCP gateway?  That would explain why you are getting the error about a missing file.  It would appear the solution is to remove the MGCP configuration altogether.
Content for Community-Ad
