TFTP: Looking for jar75sip.9-1-1TH1-16.sbn
me.saadiqbal
Hi there,
I have a CME/CUCME 8.6 running on ISR G2 2901 router,
I am trying to register a 7975 phone? I am woundering why it is looking for SIP jar file?
Is it not that SCCP should be default? Or not ? what is the reason it is looking for SIP?
I am not able to register this phone any sugguestions?
I have tried no create cnf-files and create cnf file, and also no create profile and create profle,
Also I have added the load command for the specfic phone type
Also I have added the tftp- command on the gloabal along with the alias command?
Anything I have missed?
IQBAL
me.saadiqbal
When I restart the phones, this is what I see in the debug
Dec 24 09:25:14.274: TFTP: Looking for term75.default.loads
Dec 24 09:25:14.278: TFTP: Opened flash0:term75.default.loads, fd 4, size 660 for process 223
Dec 24 09:25:14.278: TFTP: Finished flash0:term75.default.loads, time 00:00:00 for process 223
Dec 24 09:25:15.298: TFTP: Looking for jar75sip.9-1-1TH1-16.sbn
Dec 24 09:25:15.674: TFTP: Looking for term75.default.loads
Dec 24 09:25:15.674: TFTP: Opened flash0:term75.default.loads, fd 4, size 660 for process 223
Dec 24 09:25:15.678: TFTP: Finished flash0:term75.default.loads, time 00:00:00 for process 223
Dec 24 09:25:16.310: TFTP: Looking for jar75sip.9-1-1TH1-16.sbn
thanks,
IQBAL
The phone continues to reboot and go in a loop, and this is what I get in the bebug messages;
Dec 24 11:14:54.390: TFTP: Looking for term75.default.loads
Dec 24 11:14:54.394: TFTP: Opened flash0:term75.default.loads, fd 4, size 660 for process 223
Dec 24 11:14:54.394: TFTP: Finished flash0:term75.default.loads, time 00:00:00 for process 223
Dec 24 11:14:55.414: TFTP: Looking for jar75sip.9-1-1TH1-16.sbn
Mohammed,
First of all you need to check what firmware is on the phone at the moment. If the firmware on the phone is earlier than 8.5 release then you need to downgrade the firmware on your ccme to an 8.5 release. Phones firmware prior to 8.5 release cant migrate directly to a 9.x release. So I suggest you start from there.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Hi There,
Because the phone is in the reboot cycles, I can not see what firmware it is holding.
However, what I did was , I disconnected the IP Phone from CUCME 8.6 and connected to 8.0 CUCM.
So, the phones shows SCCP 75.9-0-3S, then I again connected to CUCME, the debug errors have changed to
ec 25 06:46:58.241: TFTP: Looking for CTLSEP00235E17F216.tlv
Dec 25 06:46:58.293: TFTP: Looking for ITLSEP00235E17F216.tlv
Dec 25 06:46:58.349: TFTP: Looking for ITLFile.tlv
Dec 25 06:46:58.529: TFTP: Looking for SEP00235E17F216.cnf.xml.sgn
Dec 25 06:46:58.645: TFTP: Looking for XMLDefault.cnf.xml.sgn
But when I again when I did factory default on the phone, the old erros have re-appeared, i.e,
Dec 25 06:50:44.581: TFTP: Looking for term75.default.loads
Dec 25 06:50:44.585: TFTP: Opened flash0:term75.default.loads, fd 4, size 660 for process 223
Dec 25 06:50:44.585: TFTP: Finished flash0:term75.default.loads, time 00:00:00 for process 223
Dec 25 06:50:45.333: TFTP: Looking for jar75sip.9-1-1TH1-16.sbn
