10-06-2011 04:20 AM - edited 03-16-2019 07:21 AM
I am upgrading CUCM cluster consisting of 2 servers (Pub and Sub) from 7.1(4) to 7.1(5)SU3. Currently one of those servers serve as TFTP server. Also russian locale is installed on both servers (cm-locale-ru_RU-ES-7.1.5.1100-1.cop.sgn). There are also several desktops on TFTP server and MoH files. I am wondering if these files will stay on server after upgrade or not?
Thanks a lot/
Solved! Go to Solution.
10-06-2011 07:26 AM
Yes, those files are in a common partition and not in the ones used for the actual CUCM/OS.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-06-2011 07:35 AM
Hi Sergey,
Just to add a note to the great info from my friend Java (+5 "J")
You will likely need the latest locale after this upgrade
cm-locale-ru_RU-7.1.5.1200-1.cop.sgn | |
Release Date: 16/SEP/2010 | |
Cisco Unified Communications Locale Installer ES-7.1.5.1200-1 Russian (Russian Federation) for Cisco Unified Communications Manager 7.1 | |
Size: 22589.85 KB (23131998 bytes) |
Cheers!
Rob
10-06-2011 07:26 AM
java
10-02-2015 12:28 PM
If i am upgrading cucm OS from 10.5.2 to 10.5.2.SU2a do i also need to upgrade the tftp servers ?
I also have several different locales on the server... do those need to be upgraded also ?
10-02-2015 12:31 PM
Yes, ALL the servers in the cluster need to be running the same CUCM release, if there are updated locales, yes, you should install the most recent ones, if there are not, you can keep the ones you're using.
10-09-2015 06:16 AM
Thanks man... it made more sense when I realized this customer had two dedicated TFTP / MOH servers for their cucm cluster. I was assuming the TFTPs were hosted off a couple of the call manager servers and was having a hard time trying to figure out how to upgrade just the TFTP portion of a server that was already upgraded.
Thanks again ... !!!
10-06-2011 07:35 AM
Hi Sergey,
Cheers!
Rob
10-06-2011 11:40 PM
Guys, thanks for your help again.
Upgrade went well. And we didn't use this latest locale, coz the old one seems to work fine. Is it worthy to upgrade locale, you think? Does it require server restart to work properly?
