02-24-2018 11:58 PM - edited 03-17-2019 12:17 PM
hi all
which ios version is the best for cisco router 2811?
in case of using this scenario:
Panasonic TDA100 (PRI 0290) ---> (e1)< cisco 2811> (sip trunk) ----> softx3000
thanks in advance
02-25-2018 12:17 AM
The current "gold star" release is 15.1.4M12a:
02-25-2018 12:49 AM
Hi there
i have a 64M compact flash on 2811 router ,
I'm going to use c2800nm-advipservicesk9-mz.151-4.M12a.bin
thanks in advance
02-26-2018 05:09 AM
11-06-2018 02:35 AM
I don't know about anyone else, but I had a lot of memory leak issues with 15.1(4)M12a regarding DNS, eventually required rebooting every 24 hours... These are issues I did not have with 12.x IOS. you might consider grabbing the last version of 12.x you can get to have it on the flash also...
