AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
3042
Beginner
The best ios version for 2811 router ?
hi all
which ios version is the best for cisco router 2811?
in case of using this scenario:
Panasonic TDA100 (PRI 0290) ---> (e1)< cisco 2811> (sip trunk) ----> softx3000
thanks in advance
4 REPLIES 4
VIP Advisor
Re: The best ios version for 2811 router ?
Beginner
Hi there
i have a 64M  compact flash on 2811 router ,
I'm going to use c2800nm-advipservicesk9-mz.151-4.M12a.bin
thanks in advance
That's the best you can use. Since the device is EOL/EOS, there won't be anymore software releases.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Highlighted
Beginner
I don't know about anyone else, but I had a lot of memory leak issues with 15.1(4)M12a regarding DNS, eventually required rebooting every 24 hours...   These are issues I did not have with 12.x IOS.  you might consider grabbing the last version of 12.x you can get to have it on the flash also...
CCIE# 6771
Content for Community-Ad
August's Community Spotlight Awards
