05-15-2023 11:48 PM
Hi Community,
I would like to add to CUCM 14SU2 3rd Party device and use an encryption for the registration and srtp.
From the instruction guidy I see this:
However trying to register the device, I will get SIP 405 Method Not Allowed. Does CUCM support TLS on 3rd party devices? The issue is not on the TLS layer. The negotiation works just fine.
Do you have any experience with that integration. 3rd Party SIP Device Advance works just fine.
Thank you for your help.
05-16-2023 12:21 AM
Is your device registering successfully without encryption?
Have you checked the phone security profile settings?
Do you have encryption working for "normal" Cisco phones or is this your first phone?
05-16-2023 03:15 AM
Have you completed required configurations on cucm like the secure sip profile etc?
Make sure you have export restriction option on SA and selected this when creating token to register cucm with SA
