Third Party SIP Software Client Phone not able to register Cisco CME
amalmichaelvj
Hello guys,
Do anyone have experienced configuring Cisco CME for third party SIP client as application in PC.
Client trying to register in CME but not able to register.
Please check my Config for ephone 12
ephone 12
username "user12" password 2812
voice register pool 12
id mac 0000.0000.0012
number 1 dn 12
voice-class codec 1
username user12 password 2812
voice register dn 12
number 2812
name user12
voice register global
mode cme
source-address 10.0.2.151 port 5060
timeouts interdigit 5
max-dn 15
max-pool 15
authenticate register
timezone 35
date-format D/M/Y
tftp-path flash:
create profile sync 001144523571219A
auto-register
voice service voip
no ip address trusted authenticate
gcid
callmonitor
cti message device-id suppress-conversion
cti csta mode basic
no cti shutdown
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
supplementary-service media-renegotiate
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
registrar server
------------------ show version ------------------
Cisco IOS XE Software, Version 16.06.09
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.9, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Wed 24-Feb-21 09:21 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
cme uptime is 44 weeks, 1 day, 23 hours, 31 minutes
Uptime for this control processor is 44 weeks, 1 day, 23 hours, 34 minutes
System returned to ROM by Reload Command at 17:15:12 utc Wed Nov 29 2023
System image file is "bootflash:isr4300-universalk9.16.06.09.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 uck9 Permanent uck9
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1795969K/6147K bytes of memory.
Processor board ID FDO2451M29A
3 Gigabit Ethernet interfaces
16 Serial interfaces
1 Channelized E1/PRI port
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
me# show telephony-service
CONFIG (Version=12.0)
Version 12.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.0.2.151 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
load 7960-7940 cmterm-7940-7960-sccp.8-1-1
load 7942 SCCP42.9-3-1SR4-1S
max-ephones 10
max-dn 10
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
moh music-on-hold.au
time-format 12
date-format dd-mm-yy
timezone 35 Arabian Standard Time
call-park system application
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
night-service time is deactivated
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message EMPOWER
web admin system name Admin
web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
Log (table parameters):
max-size: 200
retain-timer: 30
create cnf-files version-stamp Jan 01 2002 00:00:00
transfer-system full-consult
transfer-digit-collect new-call
multicast moh 239.10.16.4 port 16384
route 10.0.2.151
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
The CME portion looks essentially correct. I assume you have "registrar server" under voice service voip - sip and other global SIP settings for voice.
The biggest problem I have had getting 3rd party SIP phones to register with either CUCM or CUCME are the settings in the endpoint itself. Which endpoint are you using? You can also check the registration attempts using the following debugs:
debug voice register event
debug ccsip messages
Maren
Hello Maren,
Yeah, configurations are there..
voice service voip
gcid
callmonitor
cti csta mode basic
no cti shutdown
sip
registrar server
let me check debugs..
