06-25-2008 01:49 AM - edited 03-15-2019 11:31 AM
Hi Guys,
I'm really interested in getting an idea of how to use EEM Tcl scripts or other method to get PoE for our phones switched off at night to save power. Does anyone know if there's any whitepapers on doing this? I saw the idea on a Cisco slide already and have searched real hard to find a solution but to no avail. All I'm after is PoE being switched off on a port range between 19:00 and 06:00 simple as that!
06-25-2008 02:03 AM
I'm not sure that you will save much power if any at all.
Due to the nature of the power supplies used, absorbtion on mains is not linearly proportional to the number of phones connected.
You can have an electrician measure it, with and without the PoE enabled, then judge yourself if it is worth to do that or not.
06-25-2008 02:20 AM
Hi buddy,
I'm curious why Cisco pimped the idea as a way of being more power efficient if the power supply is pulling constant power regardless of PoE usage. I hope this isn't a case of 'jumping on the green bandwagon' from Cisco. It'd be dissapointing if it is.
I've got a spare 3560PoE switch kicking around so I can power that up - monitor it, then run round to our production switches which are fully PoE enabled and used, then compare the two power consumption results. In the meantime - if anyone does now how to do this using EEM then please post as I'd like to provide the option should my test prove useful. I'll also post my power consumption results for everyones benefit.
06-25-2008 03:27 AM
Hi, EEM has a dedicated area on CCO where scripts are collected and discussed I think.
There are also a pair of whitepapers on the subject on CCO.
You can also find that it's easier to use some scripting on a PC based on "expect" that telnet to the switch and issues the commands based on a schedule.
06-25-2008 04:44 AM
That's great, could you please link to them. As I've already mentioned I'm having a pig of a time finding configuration/white papers on the subject.
The original document that spawned this thread was http://www.cisco.com/en/US/prod/switches/cfs_certifiedgreen_podcast.pdf
Looking forward to those links!
06-25-2008 05:17 AM
Portal to all EEM things:
06-25-2008 06:21 AM
I can see one problem with this.
What happens if, after the phones are powered off, someone is stuck in the building or their is a fire how do they call anyone ?
06-25-2008 07:36 AM
Yup! And the script does not run for some reason to turn on the phones in the morning. Business is down. How much does that cost per minute of downtime vs how much you are actually saving on your power bill vs "green marketing" material for your enterprise?
Safety
Reality
ROI
Those are my three. Turning off POE would be great. But safety. Having the screens go blank like a screen saver, much better. They would draw less power from the switch. (assuming)
