01-12-2013 10:59 AM - edited 03-16-2019 03:08 PM
Earlier in the week, I had recreated time schedules and applied to two new partitions to handle after-hours calls. In those partitions, i created a simple translation pattern to route the call appropriately. It was working, but then yesterday, we cutover a new location to CM and now none of the locations are able to use the routing and calls are failing. If i go through DNA, it shows 'block this call' 'unallocated number'; when i check the order of partitions in the device CSS that's being applied, it skips over the first two, which have the time of day, and goes straight into a 3rd one with a generic pattern to allow intra-office abbreviated dialing...callmanager version is 8.5.1-13900
Any ideas as to what might've happened?
01-12-2013 01:12 PM
What changes where made exactly? Did you install another cm in a branch office? Where any route patterns changed? Are the GW registered?
Yosh
01-12-2013 01:15 PM
Hi Yosh--actually, about an hour into it, I had the engineer from our VAR take a look, and apparently, I missed all of Saturday and most of Sunday in the time periods...that's what i get for not having someone take a look when i built it out--hard to recognize flaws in your own code.
After adding those in, though, they're working as intended once again.
SJ
