07-26-2007 08:56 AM - edited 03-14-2019 10:47 PM
Hi all,
there is any option to use cor list with a time range?
07-26-2007 10:11 AM
Not really. If using CME, you can check if "after-hours" blocking would do for your needs, as it allow time-based configuration.
07-26-2007 02:41 PM
I know, but with after-hours configuration, i block fxo port too...
07-26-2007 03:24 PM
Actually it prevents certain phones from dialing certain calls starting with numbers you decide. FXO ports are not affected directly.
10-19-2012 06:40 AM
I have a cme and I want some specific phones to call only internal number on non-working hours..
Do you have an idea how I can do this?
10-19-2012 09:36 AM
Use after-hours to achieve that. More information can be found at this link, http://voipnewb.blogspot.se/2009/08/cme-after-hours-call-blocking.html?m=1
Please rate all useful posts.
