tomcat service showing status starting
Pawan Arora
I am building a new setup of call manager 8.6.2. I have successfully installed publisher and subscriber in my cluster. But when i am trying to open the web page of subscriber it give me an error "the page cannot be displayed". I checked the service on the subscriber, the tomcat service is showing from last an hour. I have also tried to start and stop the tomcat service but it didn't work.
Pawan Arora
17 Replies 17
nikshah
Pawan
can you run the following command utils diagnose test on the subscriber
also can you post the output of stopping and starting the service , also can you send the output of utils service list.
Niket
Hi Niket,
Please find below diagnose test. Will send yo start and stop command output later,
admin:utils diagnose test
Log file: platform/log/diag1.log
Starting diagnostic test(s)
test - disk_space          : Passed (available: 29425 MB, used: 11726 MB)
skip - disk_files          : This module must be run directly and off hours
test - service_manager     : Passed
test - tomcat              : Passed
test - tomcat_deadlocks    : Passed
test - tomcat_keystore     : Passed
test - tomcat_connectors   : Failed - The HTTPS port is not responding to local requests.  Please collect all of the Tomcat logs for root cause analysis: file get activelog tomcat/logs/*
test - tomcat_threads      : Passed
test - tomcat_memory       : Passed
test - tomcat_sessions     : Passed
test - validate_network    : Passed
test - raid                : Passed
test - system_info         : Passed (Collected system information in diagnostic log)
test - ntp_reachability    : Passed
test - ntp_clock_drift     : Passed
test - ntp_stratum         : Failed
The reference NTP server is a stratum 12 clock.
NTP servers with stratum 5 or worse clocks are deemed unreliable.
Please consider using an NTP server with better stratum level.
Please use OS Admin GUI to add/delete NTP servers.
skip - sdl_fragmentation   : This module must be run directly and off hours
skip - sdi_fragmentation   : This module must be run directly and off hours
test - ipv6_networking     : Passed
Diagnostics Completed
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco Audit Event Service[STARTED]
Cisco CAR DB[STOPPED]  Commanded Out of Service
Cisco CAR Scheduler[STOPPED]  Commanded Out of Service
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STOPPED]  Commanded Out of Service
Cisco CallManager Admin[STOPPED]  Commanded Out of Service
Cisco CallManager Cisco IP Phone Services[STOPPED]  Commanded Out of Service
Cisco CallManager Personal Directory[STOPPED]  Commanded Out of Service
Cisco CallManager Serviceability[STOPPED]  Commanded Out of Service
Cisco CallManager Serviceability RTMT[STOPPED]  Commanded Out of Service
Cisco Certificate Change Notification[STARTED]
Cisco Certificate Expiry Monitor[STARTED]
Cisco Change Credential Application[STOPPED]  Commanded Out of Service
Cisco DRF Local[STARTED]
Cisco DRF Master[STOPPED]  Commanded Out of Service
Cisco Database Layer Monitor[STARTED]
Cisco Extension Mobility Application[STOPPED]  Commanded Out of Service
Cisco License Manager[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco RIS Data Collector[STARTED]
Cisco RTMT Reporter Servlet[STOPPED]  Commanded Out of Service
Cisco SOAP - CallRecord Service[STOPPED]  Commanded Out of Service
Cisco Syslog Agent[STARTED]
Cisco Tomcat[STARTING]
Cisco Tomcat Stats Servlet[STOPPED]  Commanded Out of Service
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STOPPED]  Commanded Out of Service
Cisco Trust Verification Service[STARTED]
Cisco User Data Services[STOPPED]  Commanded Out of Service
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
Native Agent Adapter[STARTED]
SNMP Master Agent[STARTED]
SOAP - Diagnostic Portal Database Service[STOPPED]  Commanded Out of Service
SOAP -Log Collection APIs[STOPPED]  Commanded Out of Service
SOAP -Performance Monitoring APIs[STOPPED]  Commanded Out of Service
SOAP -Real-Time Service APIs[STOPPED]  Commanded Out of Service
System Application Agent[STARTED]
Cisco AXL Web Service[STOPPED]  Service Not Activated
Cisco Bulk Provisioning Service[STOPPED]  Service Not Activated
Cisco CAR Web Service[STOPPED]  Service Not Activated
Cisco CTIManager[STOPPED]  Service Not Activated
Cisco CTL Provider[STOPPED]  Service Not Activated
Cisco CallManager[STOPPED]  Service Not Activated
Cisco CallManager SNMP Service[STOPPED]  Service Not Activated
Cisco Certificate Authority Proxy Function[STOPPED]  Service Not Activated
Cisco DHCP Monitor Service[STOPPED]  Service Not Activated
Cisco Dialed Number Analyzer[STOPPED]  Service Not Activated
Cisco Dialed Number Analyzer Server[STOPPED]  Service Not Activated
Cisco DirSync[STOPPED]  Service Not Activated
Cisco Extended Functions[STOPPED]  Service Not Activated
Cisco Extension Mobility[STOPPED]  Service Not Activated
Cisco IP Manager Assistant[STOPPED]  Service Not Activated
Cisco IP Voice Media Streaming App[STOPPED]  Service Not Activated
Cisco Messaging Interface[STOPPED]  Service Not Activated
Cisco SOAP - CDRonDemand Service[STOPPED]  Service Not Activated
Cisco Serviceability Reporter[STOPPED]  Service Not Activated
Cisco TAPS Service[STOPPED]  Service Not Activated
Cisco Tftp[STOPPED]  Service Not Activated
Cisco UXL Web Service[STOPPED]  Service Not Activated
Cisco Unified Mobile Voice Access Service[STOPPED]  Service Not Activated
Cisco WebDialer Web Service[STOPPED]  Service Not Activated
Platform SOAP Services[STOPPED]  Service Not Activated
Primary Node =false
Pawan Arora
Ayodeji Okanlawon
What hardware are you using? Is this vmware? I suggest you try and reboot your servers
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
I am using 7825 server. Please find below the hardware of the server
HW Platform       : 7825I5
Processors        : 1
Type              : Intel(R) Xeon(R) CPU           X3430  @ 2.40GHz
CPU Speed         : 2400
Memory            : 4096 MBytes
Object ID         : 1.3.6.1.4.1.9.1.746
OS Version        : UCOS 5.0.0.0-2
can you try utils service restart Cisco Tomcat and log the session and send the output as well..
also pawan do you have any third party servers talking to the publisher/subscriber servers via the AXL service
Hi Niket,
No there is not third party server. This is fresh setup
Pawan Arora
did you try
performin utils service restart Cisco Tomcat on the subscriber.
yes, i have run the command and it is still executing
admin:utils service restart Cisco Tomcat
Hi Pawan,
Try rebooting the server and see if it helps.
Niket
Pawan,
Try and restart the server and see if the service comes back as I suggested earlier
I have already tried that but it didn't help...let me do it again
Hi Pawan,
Can u cross-check the database replication between PUB and SUB using utils dbreplication runtimestate command?
regds,
aman
Hi Aman,
Please find below the output of the command:
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Only available on the PUB
DB Version: ccm8_6_2_20000_2
Number of replicated tables: 541
Cluster Detailed View from SUB (2 Servers):
                                PING            REPLICATION     REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES  LOOP?   (RTMT)
NWJPUB  10.150.3.30     0.120   Yes     Connected       0       match   Yes     (2)
NWJSUB  10.150.3.29     0.024   Yes     Connected       0       match   Yes     (2)
