10-24-2015 01:46 PM - edited 03-17-2019 04:41 AM
A typical Setup message used to look like this:
Oct 24 20:31:10.044: ISDN Se0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0080
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8583 - Origination address is non-ISDN
Calling Party Number i = 0x80, '9725900222'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '8303'
Oct 24 20:31:10.072: ISDN Se0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8080
In newer IOS 15.1(4)M9 the same message looks like this:
Oct 24 15:34:44.141: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0081
Standard = CCITT
Signal i = 0x40 - Alerting on - pattern 0
Calling Party Number i = 0x2180, '9725900222'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '8306'
Locking Shift to Codeset 5
Codeset 5 IE 0x41 i = 0xC4890000000000
Oct 24 15:34:44.153: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8081
Cause i = 0x80E4 - Invalid information element contents
Differences are in red. Is there any way to take them out? My other ISDN device doesn't like this new Setup message.
Thank you!
10-24-2015 02:40 PM
Hi.
Can you please send your actual config?
Carlo
10-24-2015 03:22 PM
10-24-2015 11:12 PM
Hi.
Maybe your provider does not accept Numbering plan "Unknown"
Try to set it to Subcriber or National modifying route pattern on cucm or applying a voice translation profile on dialpeer
Please let me know
Carlo
10-25-2015 01:21 AM
Hi Experts,
Greetings
I am calling from IP Phone to PSTN & called party is not answering my call, after some rings call is getting hangup and i am not able to hear hangup tone or beep, rather i am getting system recording like "your call can not be completed as dialed please console your directory"
Please advise me to remove the system recording & let me able to get beep tone after called party not answering call
Thanks in advance
Warm Regards:
Nabeel Asghar
10-26-2015 05:41 AM
Tried that idea, but didn't solve the problem. Please note the response I've got:
10-26-2015 05:55 AM
Hi.
Please under voice-port 0/0/0:23 and 0/0/1:23 add "bearer-cap speech" and "command-type A-LAW"
Let me know
Carlo
10-29-2015 11:05 AM
Tried these suggestions, still no fix. Thank you.
10-30-2015 04:15 AM
Hi.
Please download 15.1.4M10 and upgrade your VG.
Let me know if it solves your issue.
Carlo
12-06-2016 04:48 AM
Hi, I have the same issue...
Were you able to fix it?
If yes, how please?
12-06-2016 06:08 AM
MLPP adds those messages. Turn MLPP off to remove those lines.
12-06-2016 06:21 AM
Effectively no voice mlpp fixes the issue! Many thanks.
