Too much information in ISDN Setup Message
omihut
A typical Setup message used to look like this:
Oct 24 20:31:10.044: ISDN Se0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0080
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8583 - Origination address is non-ISDN
        Calling Party Number i = 0x80, '9725900222'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '8303'
Oct 24 20:31:10.072: ISDN Se0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8080
In newer IOS 15.1(4)M9 the same message looks like this:
Oct 24 15:34:44.141: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0081
                Standard = CCITT
        Signal i = 0x40 - Alerting on - pattern 0
        Calling Party Number i = 0x2180, '9725900222'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, '8306'
        Locking Shift to Codeset 5
        Codeset 5 IE 0x41  i = 0xC4890000000000
Oct 24 15:34:44.153: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8081
        Cause i = 0x80E4 - Invalid information element contents
Differences are in red.  Is there any way to take them out?  My other ISDN device doesn't like this new Setup message.
Thank you!
11 Replies 11
Hi.
Can you please send your actual config?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Please see attached relevant config.
Hi.
Maybe your provider does not accept Numbering plan "Unknown"
Try to set it to Subcriber or National modifying route pattern on cucm or applying a voice translation profile on dialpeer
Please let me know
Carlo
Hi Experts,
Greetings
I am calling from IP Phone to PSTN & called party is not answering my call, after some rings call is getting hangup and i am not able to hear hangup tone or beep, rather i am getting system recording like "your call can not be completed as dialed please console your directory"
Please advise me to remove the system recording & let me able to get beep tone after called party not answering call
Thanks in advance
Warm Regards:
Nabeel Asghar
Tried that idea, but didn't solve the problem.  Please note the response I've got:
Hi.
Please under voice-port 0/0/0:23 and 0/0/1:23 add "bearer-cap speech" and "command-type A-LAW"
Let me know
Carlo
Tried these suggestions, still no fix.  Thank you.
Hi.
Please  download 15.1.4M10 and upgrade  your VG.
Let me know if it solves your issue.
Carlo
Hi, I have the same issue...
Were you able to fix it?
If yes, how please?
MLPP adds those messages.  Turn MLPP off to remove those lines.
Effectively no voice mlpp fixes the issue! Many thanks.
