Trancoding on ISR2921
tkavithas87
I am trying to create trancoding on the 2921 router.
It has pvdm 3
when i create the  profile ,couldnt assign codec to the profile.what could be the cause?
2921(config)#dspfarm profile 1 transcode
2921(config-dspfarm-profile)#codec ?
% Unrecognized command
2 Accepted Solutions
If you had a PVDM installed, your output of sh inventory would contain similar to below depending upon channels:
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32 , VID: V01 , SN: FOCxxxx
Please let us know if you have further questions or please mark the thread answered.
Terry
Please rate useful posts.
Harmit Singh
Hi Kavithas,
Terry is spot on (+5)! You should be able to see the PVDM module in the show inventory or show diag. If you're absolutely sure there should be a PVDM in there, then it's possible that the PVDM hasnt been seated into the PVDM slot properly or the slot has gone bad or the PVDM has gone bad. Assuming the PVDM is present, then pop open the chassis cover (powered down ofcourse) and try the other PVDM slot. If it gets detected, you know the PVDM is fine but the slot is bad.
HTH.
Harmit.
9 Replies 9
Terry Cheema
Can you post the output of -
sh inventory
sh ver | i IOS
It appears router isn't detecting pvdm
-Terry
2921#show inventory
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: FGL1636147P, Hw        Revision: 1.0"
PID: CISCO2921/K9      , VID: V07 , SN: FGL1636147P
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V03 , SN: DCA1633K1L0
2921#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 07-Nov-12 14:08 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
2921 uptime is 2 hours, 32 minutes
System restarted at 09:20:12 sg Sat Feb 23 2013
System image file is "flash:c2900-universalk9-mz.SPA.152-4.M2.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL1636147P
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FGL1636147P
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
2921#show run | s voice-card
voice-card 0
dsp services dspfarm
Based on the output of your sh inventory output either there is no PVDM installed or router is not detecting, you can try reseating if you have installed one.
Terry
Please rate all helpful posts.
Terry
Harmit Singh
Hi Kavithas,
HTH.
Harmit.
Harmit - thanks for the nice rating buddy. +5 for your accurate post as well!
-Terry
yeah the PVDM is not slotted correctly.I have slotted correctly .its working now.thank you guys.
Not a problem mate - glad it resolved your issue!
- Terry
Glad to hear that, see you around! :-)
Harmit.
