dinorubio
Beginner
Transcode in SRST
is it possible to transcode in SRST mode?
thank you all,
Dino
16 REPLIES 16
Great stuff here, thanks.
my scenario is a centralized CCME and remote gateways that their phones are all registered in the central CCME. there are no T1's or E1's it's all IP traffic/voice. the softswitch is a software that processes all traffic that comes from a TDM commuter. you must see this scenario from as ISP perspective.
ok, so i have ccme in one router and srst on others, do i have to purchase another license to put ccme srst on the other? or i can use the same license?
thanks all,
Dino
forget the licenses!
i will now do some tests with the ccme srst on remote gw and see if it fulfill's the engineering requesites.
thanks all!
Dino
Content for Community-Ad
Spotlight Awards 2021
