Transcoder - Conference Bridge query
singh-ashok
I have a query - in an MRGL in CUCM 7x, where no hardware conference bridge exists, can
a Transcoder fulfill the function of Hardware Conf Bridge ?
2 Accepted Solutions
Payal Bhaduri
you can include a software conference bridge in the MRGL along with a transcoder. This will help you achieve functionality of a hardware conference bridge.
Jaime Valencia
To answer your question, NO.
A HW CFB can also work as an MTP, but an MTP CANNOT do the functions of a CFB.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Payal Bhaduri
Jaime Valencia
java
java
Are you really sure about
"A HW CFB can also work as an MTP, but an MTP CANNOT do the functions of a CFB."
Is it documented anywhere?. I would like a link to it. Not been able to find it.
I know a Xcoder can act like a MTP. CFB as a MTP is new to me
I would just go with pbhaduri's Suggestion (Xcoder + Software CFB).
You're right, nevermind. I was thinking of an XCODER but somehow I typed CFB.
java
java
