Transcoding 2901
j.huizinga
Frequent Contributor
I have a 2901 with 1 x PVDM3-32 and 1x PVDM3-64
The only interface card that uses the DSP's is a VWIC2-2MFT-T1/E1
I want to add a transcoder using the LTE interface, I think I should have enough DSP's, but max sessions says <0-0>
As far as I can see the PVDM3-32 should be free for transcoding services
Any idea why I have no transcoding sessions?
JH
7 Replies 7
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Can you post "show run" and "show diag"?
j.huizinga
Hello Chris
Attached the config, I have removed some config like dial-peers and sip-ua config
Jan
Since you have 2 E1-PRIs the 64+32 channel PVDMs with flex complexity all may be allocated to your PRIs, I suggest you read the following great write up on DSP credits to confirm if that is the case:
https://community.cisco.com/t5/collaboration-voice-and-video/understanding-the-output-of-quot-show-voice-dsp-group-all-quot/ta-p/3141792
As an additional resource, this excellent explanation from Vik: https://youtu.be/vlm3wqurlqs
Very good video, thanks for posting Anthony.
j.huizinga
I did an IOS upgrade and suddenly I have max sessions 23.
The IOS was quite old for this 2901
I saw that the DSPWARE VERSION went from 20 something to 46.2.12
Thank you all for the advice and links
very good, thinking about it the single PVDM3-64 should have covered your 2 E1s, so this makes sense now.
Recognize Your Peers
