12-06-2019 04:45 AM
I have a 2901 with 1 x PVDM3-32 and 1x PVDM3-64
The only interface card that uses the DSP's is a VWIC2-2MFT-T1/E1
I want to add a transcoder using the LTE interface, I think I should have enough DSP's, but max sessions says <0-0>
As far as I can see the PVDM3-32 should be free for transcoding services
Any idea why I have no transcoding sessions?
JH
12-06-2019 05:42 AM
Can you post "show run" and "show diag"?
12-06-2019 07:48 AM
12-07-2019 09:27 AM
Since you have 2 E1-PRIs the 64+32 channel PVDMs with flex complexity all may be allocated to your PRIs, I suggest you read the following great write up on DSP credits to confirm if that is the case:
12-07-2019 10:07 AM
12-08-2019 07:18 AM
Very good video, thanks for posting Anthony.
12-08-2019 04:24 AM
I did an IOS upgrade and suddenly I have max sessions 23.
The IOS was quite old for this 2901
I saw that the DSPWARE VERSION went from 20 something to 46.2.12
Thank you all for the advice and links
12-08-2019 07:19 AM
very good, thinking about it the single PVDM3-64 should have covered your 2 E1s, so this makes sense now.
