Transcoding configured on CUBE - ISR G2
dapo100
I am looking for the confirmation that DSP transcoding ressources on CUBE ISR G2 can be used by the CUCM in a scenario where the same DSPressources can be used as transcoder for the SIP trunk connection to the ISP ( CUBE acts as SBC too). Is there a possibility to split/dedicate the DSP ressources for the two different functions or I need to even dedicate a separate DSP gateway as a HW CUCM transcoder?
thanks.
Dan P
Rajan
Hi Dan,
If you have enough DSP resources in CUBE to configure transcoding sessions, then you could add that trancoder in an MRG/MRGL and use it in the SIP trunk in CUCM.
Rajan
Please rate all useful posts
Rajan
Hi Dan,
Rajan
