transcoding requirement
techguy
Level 4
Level 4
For a gateway do we need to have transcoding (pstn in/out)
Transcoding is related to interface meaning do we need a physical interface or Tunnel interface
Ayodeji Okanlawon
Omerpal,
For PSTN calls, no you dont need transcoding resources because the DSPs does that for you.
Pls rate useful posts
Please rate all useful posts
Transcoding is related to interface meaning do we need a physical interface or Tunnel interface ( in case of gateway connected to cucm)
Transcoding is done using SCCP protocol and SCCP does not support using Tunnel interface. So you either use loopback or physical interface.
