Highlighted
Beginner
Transcoding via Enhanced IOS in CUCM 6.0
Is there a way to have hardware transcoding in CUCM 6.0 using IOS/DSP? The latest sccp ccm version I can find is 5.0.1, which I know works in 5.1.2 at least, but will not register to a version 6 CUCM. Thanks.
2 REPLIES 2
Hall of Fame Master
Re: Transcoding via Enhanced IOS in CUCM 6.0
You may need a newer version IOS, typically I found that entering previous versions works fine, also try leaving it without a version.
Chris
Beginner
Thanks for the tips. I had tried without version to no avail, and have tried the latest adventerprise 12.4.15(T1) and 12.4.17. If I go outside of adventerprise, I need to make sure I am still supporting our SIP Unified Border Element with another feature set.
Content for Community-Ad
July's Community Spotlight Awards
